I have an oil mess in the fuel pump area and cannot locate any obvious locations other than the pump itself.
The crimp seems tight,any ideas? Its an AC 40727 with the AC cast onto the body.
"Knowledge is good" Emil Fabor 67 L/78 Camaro SS/RS H-H,1W,2LGSR,3SL,4K,5BY. (Sold) 70 L/78 Nova M-21,Black Cherry,Sandalwood Int. 09 Pontiac G8 GT Premium,Sport,Roof. Liquid Red. |
If you have another pump...clean the area good..and replace and see what you get. Maybe the internals are shot...that could mean gas in the oil...do a sniff test on the dipstick.
-wilma
Hi, Wilma.
No gas in the oil. I was going to simply change the pump but the AC logo on the body versions are NLA. Only 200 miles on this one but it must have been sitting around for a while. I guess I'll pop a cheapie on there and see.
I know that Dave Beem had his original LS6 fuel pump restored. If I am not mistaken they put vitol pump diaphrams in them so the ethanol will not eat them away.
~JAG~ NCRS#65120 68 GTO HO 4 spd Alpine Blue /Parchment 2 owner car #21783 71 Corvette LT1 45k miles Orig paint - Brandshatch Green - National Top Flight - last known 71 LT1 built. 71 Corvette LT1 42k miles Original paint - Black - black leather - only black LT1 known to exist. NUMEROUS Lemans blue Camaros, Monza Red and Daytona Yellow Corvettes & a Chevelle or two... Survivors, restored cars, & other photos https://picasaweb.google.com/lh/myphotos |
How is the pipe plug seal for the fuel pump pushrod access hole?
-Dave Semper Fi! 69 Camaro SS396 L34 X66 |
![]() Quote:
Bingo! definitely on the suspicious list!
Sam... ![]() |
Hmmm. I'll check that.
Its not the plug.
I hate to sound like a buffoon, but are you certain the oil isn't running down out of the valve cover? I've seen people drop oil pans, yank engines, etc. to "fix" a rear main that was never leaking at all; merely oil coming from the back of the valve cover.
Positive not from anywhere obvious. Seems to be from the pump itself. But I've never seen a failure like this. Only a gas leak type failure.
Slow drive around the block nothing. Take it out on the highway and I have a mess. I also checked the vent system,all good.
