Old 10-21-2018, 03:25 AM
ronzz572 ronzz572 is offline
Default 69 big block camaro with a yenko block
Craigslist ad, Not sure if it could be considered a copo or yenko car. https://cleveland.craigslist.org/cto...704486210.html
1970 L78 camaro Cortez silver ralley sport under restoration
Old 10-21-2018, 03:27 AM
scuncio scuncio is offline
Original 6cyl car judging by the VIN.
Old 10-21-2018, 05:44 AM
BOWTIE67327's Avatar
BOWTIE67327 BOWTIE67327 is offline
and a TRUCK bellhousing..
Old 10-21-2018, 12:55 PM
Yeah, that truck bell housing can damage the transmission. There are a few other things that I would change too, but it's a nice car anyway.
Old 10-21-2018, 02:07 PM
Subject VIN 123379L519198
Cool car that needs a few things including removal of hokey rad support badge.
Enjoyed as is, the 6-popper Vin means little but cars like this are also just one jackass fraudster away from a whole other identity we could be looking at here in the future?
Old 10-21-2018, 07:00 PM
bbbentley's Avatar
“No aftermarket parts”....my a**. Tells me all I need to know about how reputable seller is.
FULL OWNER HISTORY
Old 10-22-2018, 05:05 PM
How could the truck bellhousing damage the transmission?
Jason
Old 10-22-2018, 09:45 PM
Igosplut's Avatar
Igosplut Igosplut is offline
Jason
Input shaft opening is larger for the truck transmissions, than it is for a Muncie.
WOT
Old 10-22-2018, 10:10 PM
The hole in the bell housing is what lines up the transmission with the crankshaft. If the hole is too large then the transmission will not line up correctly and it can damage the input shaft, gear, bearing and pilot bushing. It could also damage the pilot area on the main shaft and cause the gears to break if it's off a lot. There is about .440" difference in the hole size between the car and truck bell housing, so there is a lot of room for the transmission to be out of alignment, depending on how much clearance there is in the bolt holes. Maximum recommended out of center for the transmission is about .005".
Old 10-24-2018, 05:29 PM
Thanks guys. I thought they made that style bellhousing with both size holes. I have been wrong before and I'm sure I'll be wrong again.
Jason
