Old 06-13-2020, 12:20 AM
ssl78 ssl78 is offline
Default 1958 Corvette many upgrades
1958 Corvette
VIN# J58S105452
BODY
Fresh paint in 2006 (approx. 3000 miles driven since painted)– paint on the car is show quality!!! Black w/Silver coves with deep shine and laser straight.
Front bumpers re-chromed
New grill molding
Grill teeth & bar not replaced VGC
Rear bumpers original GC
New trunk irons/tusks
All emblems replaced w/NOS
Side trim and fender/cove trim new or polished
New front parking lights
Rear chrome brake lenses not replaced (good condition) w/LEDtail lamps upgrade
INTERIOR
Custom professionally made leather interior including seats, das pad, door panels, carpet, kick panels and trunk area. The cost to do the custom interior, trunk and custom made soft top was around 20K
New or rebuilt gauges (all work properly)
AM/FM CD with USB hook up Custom Auto Sound radio with built in speakers in kick panels and a dual speaker in dash
New shifter console plate
New door weather strips & new window felts
Hush mat installed (sound deadener under carpet to quietride)
Corvette Central electric windshield wiper upgrade ki
New ignition switch
New headlight switch
15” leather wrapped steering wheel
ENGINE &ENGINE COMPARTMENT
Polished Be-Cool Aluminum Radiator
Polished Radiator overflow tank
Electric Fan w/manual switch on dash
New Fan Shroud
Tach Drive Generator (Rebuilt)
New Voltage Regulator
Ram Horn Exhaust Manifold
New original style exhaust system
HEI ignition
New motor bracket and mounts
Engine
383 Full Roller Small block
Est.450 HP (Built in 2014)
New GM performance Block (4 Bolt Main)
Eagle street strip rotating assembly
Edelbrock Performer RPM Heads Polished
Edelbrock Performer RPMHydraulic Roller Cam kit
Weiand Action Plus intake manifold
Holley 750 cfm CFM carb with vacuum secondary’s,electric choke
Performance cam bearings
Milodon Pan 30700
Fel-Pro gasket set
Fel-Pro HP head gaskets
1 Pc pan gasket Fel-Pro
Power Master Balancer
GM Distributor gear
ARP Head Bolts SS
Roller Rocker arms SCP
Timing Chain set Roller
Oil pump 55 HV Melling Select
Brass soft plugs
TRANSMISSION &CLUTCH
Muncie 4-Speed Transmission completely rebuilt with 4thGear overdrive
New transmission mount
New Hurst Shifter
Original style bell housing
New inspection covers
New linkage
Dual friction Center Force clutch
REAR END
GM 12 Bolt
3:73 Gears
Rebuilt posi unit (new clutch packs and bearing)
New pinion and axle bearings and seals
New universal joints installed in drive shaft
CHASSIS &BRAKES
Original 1958 Frame is in very good condition painted satinblack (no rot or patches)
Original rebuilt front suspension (all new bushings and coilsprings)
Front power disc brakes
New rear brake shoes and wheel cylinders
New emergency brake cables
Steeroids power steering rack and pinion with ididit steering column and linkage
New Delco gas shocks
New Brake lines
New Gas Tank, Gas Tank Straps and Sending unit
Total wiring harness replaced
HARDTOP
New headliner
All weather stripping replaced
All glass replaced
Rear window has a scratch
SOFTTOP
Custom made convertible top
Frame complete & working
New weather seals
WHEELS
15” Halibrand Style 5 spoke polished aluminum
I have a lot of pictures let me know what you need, 82,500.00
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
Arrowsmith (06-13-2020)
Attachments - The Supercar Registry DSC_0900.JPG DSC_0896.JPG DSC_0893.JPG DSC_0892.JPG
Old 06-13-2020, 12:38 AM
Crush Crush is offline
Cool car
Old 08-15-2020, 02:23 PM
still available.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 02-21-2021, 04:45 PM
price 82,500
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
