Old 12-01-2020, 04:17 PM
SMS SMS is offline
Default Muncie Speedometer Cable Clips
My clips are all beat up. Anyone have a good original clip or two?
Thanks,
Bill
Attachments - The Supercar Registry A8B7C09D-A296-45EA-AF41-C26588C1C5CC.jpeg 4D6FBE2E-C622-462D-A03E-887A76A80931.jpeg 100_5271.jpg 100_5269.jpg
Old 12-05-2020, 08:06 PM
Bill,
I would just straighten yours for those little suckers are expensive.
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 12-09-2020, 01:37 AM
I've seen them for $100 or more when you can find them. FWIW, heartbeat now sells an exact copy and they are formed just like the originals.
TRN-1106
https://www.heartbeatcitycamaro.com/...GM%23-3772324/
Old 12-09-2020, 02:29 AM
I don't believe that the HBC clip is correct. No one makes a correct repop one.
There should be "wings" on the outside, so that when you put the holding legs into the hole, you can squeeze the wings with a pair of pliers and it spreads out the legs to make it stay put. The HBC clip has legs, but no wings.
On the HBC repro (and every other repo available) you have to have a second pair of hands inside the car to spread out the legs. They may be functional, but are not correct.
Check out post #33 in this thread.
http://www.camaros.org/forum/index.php?topic=9775.30
Although the pic shows one that was bead blasted and zinc plated. I am not sure of the correct plating.
IIRC, I have one correct on on my car and on repop one.
Old 12-09-2020, 02:35 AM
Two more pics of the correct ones in this thread: The last pic in the initial post and the pic in reply #4
http://www.camaros.org/forum/index.php?topic=14438.0
Old 12-09-2020, 09:55 PM
SMS SMS is offline
Thanks guys. I think I can make this a happy ending if I can get the one rounded out again without breaking it.
Old 12-09-2020, 10:09 PM
R68GTO R68GTO is offline
Go slow and use a "form" to apply even pressure to avoid "work hardening" it and you should be OK. This metal is very soft (and not very strong)which is how it got the way it is so easily.
Old 12-16-2020, 08:34 PM
The HBC ones are the same as everyone offers...
They also have to be "worked" in order to make them look correct!
To "fix" the clip took a good deal of work, making a little anvil and die and then filing using a multitude of needle files to fix errors.
First photo from left to right...
REPRO - ORIGINAL - Modified repro.
