Old 11-08-2021, 03:25 PM
XXXGoldL34M20's Avatar
Arrow 1970 1969 Chevelle 3938165 Assembly Line Big Block Fan Shroud
Offering a 3938165 Assembly Line Fan shroud, this one has been repaired by a professional using a plastic welder and will never come apart (See orange outlined squares for repaired areas in two spots). The bottom does not have the typical drilled out holes many added instead of using the factory clips. This one has been shaved for a 4 row radiator application.
Fits L35 L34 396 and LS5 454 with Air Conditioning, LS6 454 with 4.10 gear, L78 396 with 4.10 gear and all big blocks ordered with the optional extra cost V01 heavy duty radiator. I decided to leave the shroud as in found condition. Aside from the repairs some black paint over spray still shows here and there most likely from a previous owner detailing the motor. Next owner can smooth out the repairs on the back side further if they want to or leave "AS IS". Also to make this look nicer a light coating of SEM Landau Black Vinyl Spray Dye would be great to use for that better uniform look.
$600 USD plus $30 Shipping out of Wisconsin. Paypal "Friends" in USD only.
Old 11-26-2021, 09:19 PM
SOLD on FB
