1960-62 #1110947 distributor $35
1962 #3782461 X heads both dated A-5-2 $1250 1963 327-300HP turbo fire engine complete from the air cleaner to the steel crank. #3782870 standard bore block dated L-13-2 stamped J179687 F1217RB for a 327-300HP 4 speed block. Block has one quarter size hole in the middle of one cylinder requiring a sleeve. Can have fixed or you can have your machine shop repair it. I wanted the damage to be seen. #3782461 X heads both dated L-15-2 #3797942 & 3797901 factory exhaust manifolds #3844459 intake dated B-6-5 with factory AFB Carter carb shown as a factory service replacment intake from 1963-65 Steel Crankshaft uncut Factory turbo fire valve covers Factory air cleaner base and lid Factory water pump with original pulley and has a aftermarket fan blade Factory crank pulley Factory timing cover Factory original rods with seven pistons Sell the whole engine for $3,000 or seperate out. 1967 factory 11 inch 168 tooth flywheel #3729004 dated E-14-7 $200 1968 327 long block #3914678 standard bore block dated K-6-7 stamped T1109YC #3917291 heads dated J-11-7 & J-12-7 #39411740 cast uncut crankshaft Factory pistons and rods $1,000 for the whole set up or will seperate out. 1969 #3927186 heads 2.02 valves dated I-18-8 & K-5-8 $900 1969 #3927186 heads 1.94 valves both dated D-29-9 $750 1969 #3927186 single head dated G-25-9 $350 1969 #3927186 heads both dated K-30-8 complete 2.02 heads $900 1969 #L-13-8 & L-18-8 1.94 valves complete $800 Can ship and can provide pictures as well. A lot of the parts have been cleaned and magnufluxed or if needed can have done as well. Any questions 330-770-2517
Dennis Vugrinovich |
Gave a buddy your contact info that isn't on this site for the April 186 heads. His name is Fred and he's a good guy. Thanxs Dave
67 Z/28 Butternut Yellow 69 Z/28 Rally Green 69 Z11 Pace Car (2) 69 RS/Z28 Lemans Blue / Olympic Gold 2010 2SS RS Aqua Blue 68 Z/28 Lemans Blue C7 Corvette 68 SS Lemans Blue |
Yes I talked with him he had a car first week of may and decided that my set of April 2 1969 heads were to early for his build. I told him he should look into that because I disagree but he wants them rite on top of the build for some reason. Thank you for the opportunity.
