Old 08-09-2024, 05:45 AM
169indy's Avatar
169indy 169indy is offline
Default Reproduction tapered carb studs
For Sale; Background, I removed my Original Studs from my 1968Z intake to send to a plater for refinishing only to have them LOST by the provider. So I reverse engineered the studs using a fine commercial starter stock. I machined (Lathe work) the Dog Point (Turned down Tip) as per Original samples then glass beaded and sent them off to a different zinc plater for ATSM B38 Zinc Type II yellow chromated, wire hung plating from the UNC end that installs into the Alum Intake female threaded hole and is hidden.
Dimensions: 1.50" Nom Length overall, 11/16" effective 5/16-UNF, 5/8" effective 5/16-UNC, 5/64" Dog Point (UNF END), Mfr Dimple on the UNF End, Wire hang mark on the UNC end that will be installed in the Alum Manifold. Studs are tested for free running threads, the fine thread has slight plating build up and drags but they are hand lapped and start fine each stud is hand tested and lapped in.
Double nut them at the lowest part of the fine thread to "drive" them into the manifold. Ready to Install.
$40.00$ + Shipping (From 98311) per Set of Four (4) studs.
Clear Zinc Nuts 5/16-UNF avail at (Five Bucks additional) if Needed
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Last edited by 169indy; 08-11-2024 at 02:04 AM. Reason: Clean up pricing to fix display
The Following 3 Users Say Thank You to 169indy For This Useful Post:
Jims69z28 (08-09-2024), mhm1966 (08-09-2024), Tracker1 (08-14-2024)
Attachments - The Supercar Registry 000_0212.jpg 000_0211.jpg 000_0210.jpg 000_0209.jpg
