Cleaning shelves, yes NOS 12 bolt parts
1965 “140” posi bare 3 series case Box is dated 2-4-65 This is the early style Small Window square hole case. They are a little harder to put together but a lot more beefy. Plus, where will you find another one. $450 1968 “174” std. 4 series posi. This is what would have come in a “BV” style 12 bolt. Someone wrote May 73 but box is dated 1968. This is a Big window case. $850 I know you can take an older posi and rebuild it or buy a New aftermarket and in the Rearend nobody will know the difference, except you. Gears ‘’Rare’’ 1970 “High Impact” 4:88’s. These are stamped R50 which is 50 Rockwell . All High Impact gear were drawn down to a lower Rc and that made them softer for impact. $450 4:88 std. gears. For production These are dated 11-68 and 3-69 $350 1969/ 73 Dated 3:73 ring gear is dated ‘73 and pinion is dated ‘69. When GM did this they didn’t throw anything away so if they were spread to far apart on dates they would ink stamp a number on both parts (045) in this case. $450 3:31 dated 3-68 $400 3:08 dated 1967 $35- sorry should of been $350 Did I mention these are all GM and NOS!! If you would like more picks, text and I will get that handled. If you would like to bundle give me a call. Thanks SYC! Joe 608-751-0509 Last edited by hiperf69; 03-04-2025 at 01:06 PM. Reason: Wrong price |
The Following User Says Thank You to hiperf69 For This Useful Post: | ||
69 Post Sedan (05-02-2025) |
Cool stuff Joe!
I'm sending you a text message. I tried a PM but got a message that you don't receive PMs.
Thanks Fred for the heads up.
I will look into the PM Problem. Shows I didn’t pre-read my ad,duh! Sorry, 3:08 gear set should be $350 not $35- Joe |
Good morning SYC!!
I just sent Steve a message as I am having a Problem with receiving PM’S. If you have had a problem getting through to me just give me a text at 608-751-0509 Thank You Joe |
![]() Quote:
In the blue bar near the top of the page look at the far left side and click "user CP" From there Look at the left side of the page for Your Control Panel. It is a vertical menu of things you can do to customize your page(s). Go to "Settings and Options and click on "Edit Options", scroll down to "Private Messaging" and click on the top option to ENABLE messaging. You can do this !!
3:73,3:31 and 3:08 have been sold.
Thanks SYC!! and Charlie for the referral !! Hiperf69 Joe |
