I would appriciate some info.
I have a 69 camaro and i need some verification if possible.... I know the X33 & X77 are Z28s but i came across 2 articles showing a X-11 representing a Z28 also and with documentation. Now i dont know what to believe for sure. The car i have is a FACTORY Lemans Blue, 4 speed, 12 Bolt Posi with multi leaf rear springs, Front disc Brakes, also a Factory equipt Rear sway bar. I have the heavy front sway bar and i was told that Z28s had special Frame mounts for the engine ( I have a set on this car different from others i have built ) These are FACTORY Frame mounts and are 2 1/4 inches wide , compared to the standard ones which are wider, 2 5/8 or 2 78 , i cant remember..... ANY HELP WOULD BE GREATLY APPRICIATED .... THANKS , JC [Edited by hugger1 (02-14-2002 at 05:22 PM).] |
This would be a good question for the camaro.net website. x11 means base car with the special trim, no z28.
X trim tag codes entered production at the Norwood plant late Dec '68. They were not used at the Van Nuys, CA plant. X11 is never a Z/28.
Z/28s used the standard 11/16" front sway bar. There was no optional rear bar for '69. There was a retrofit rear bar for '67; they are extremely rare and were never installed in production. For '69 Chevrolet used the new interlock motor mount on Camaros with the 302 and 350 engines. This mount requires a different frame bracket that is 2-1/4" wide. The non-interlock mount bracket is 2-1/2" wide and about 3/8" taller. Power front discs, 12 bolt axle and 4-speed trans were optional or included with other engines, not unique to the Z/28.
THANKS for helping , ...
I am looking at a artical insuper chevy (special Camaro edition ) from 87. This issue contains Floyd Garrets Red ZL1 ( i have a call in to Floyd already ) , and BOB Porters cars ( Bob Porter Chevrolet.) Anyways , They show one of his cars and the trim tag and list it as a 69 COPO 9561 427 , Norwood built and it is a X-11 CAR and then states this can also mean a Z28 sport coupe with the Style trim group........ I know you cant believe everything you read but you would think they would have their facts right..... How to Verify a COPO ? Not that i think it is...... Thanks again , I LOVE THIS SITE. |
This is also a NON console 4 speed car if this has any meaning.
[Edited by hugger1 (02-14-2002 at 06:13 PM).] |
Many of the magazines that have "Chevy" in the title routinely publish incorrect info. This has been going on so long just about nobody takes them seriously.
In general a COPO can not be identified by VIN or body tag data. Exceptions are ZL1s and Yenko Camaros; all VINs are known for these. (well, PA Yenko Camaros...) A few guidelines: none are known to have been built in CA ("L" VIN), no L72 cars built prior to 01B. So you can rule out CA built cars and any Norwood car built prior to 01B. For the rest the only way to be certain is factory paperwork. Being that is way too easy to create a very convincing fake I wouldn't consider a non-Yenko COPO without it. X11 means it has style trim. X44 means it does not. They are unrelated to what's under the hood.
