Old 12-20-2003, 05:06 AM
bracksz28 bracksz28 is offline
Default what intake/carb combo?
I have a stock chevy 350 and want to upgrade the intake and carb, not sure what direction to go! I want build up the motor later on down the line but for now i just want to do this swap, what are some good combos?
Thanks [img]/ubbthreads/images/graemlins/flag.gif[/img]
Old 12-20-2003, 04:16 PM
PxTx's Avatar
PxTx PxTx is offline
Default Re: what intake/carb combo?
A small roots type blower and a 750 Holley (or two). You'll have so much torque there will be no need to spend money on a gear change! I wouldn't even build the motor, keep the boost around 6 psi and it will be fine.
Paul III
Old 12-20-2003, 07:25 PM
68YenkoMN 68YenkoMN is offline
try an airgap manifold and a 650 or 750 Holley
Old 12-22-2003, 01:27 AM
Fhakya Fhakya is offline
To embelish a bit on the previous post, I've also had good luck w/ the Performer RPM manifolds w/ a 3310 (750 vac. secondaries) on the street on otherwise stock 350's. They will serve you well with a stock combo but really come into their own w/ further mods. I highly recommend headers and a good exhaust as the 1st step though.
-=Mark Holman=-
Old 12-22-2003, 03:51 AM
PxTx's Avatar
Performance intakes are intended to deliver air efficiently as possible, but will never be as efficient as a blower. Even nitrous oxide is intended to cram more air and fuel in the combustion chamber (in limited doses).
It has been my personal experience that a blower on a stock engine will make better (flatter torque curve) than the equivelent money spent on a modified engine with limited RPM range. Anyone else have experience with a blower?
Some people have some sort of religion about not using forced induction, don't know why.
Weiand 144 blower goes for $2099.99
Paul III
