Old 06-08-2004, 07:54 AM
Ozark Ozark is offline
Default Actual ZL-1 Horsepower.
Does anyone know the actual HP that the ZL-1 produced? Anybody taken a stock ZL-1 and flogged it on a dyno? I know the L-88 was WAY underrated and have heard real world numbers of around 560 HP for the L-88. Given the bigger cam of the ZL-1 I would think that it would better that number.
Attachments - The Supercar Registry 86757-wheels 008.jpg 86754-wheels 022.jpg
Old 06-08-2004, 07:57 AM
Chevy454 Chevy454 is offline
Default Re: Actual ZL-1 Horsepower.
[intercom voice] Paging COPO Pete, COPO Pete to your computer, please...[/intercom voice]
Old 06-08-2004, 08:06 AM
68TopStock 68TopStock is offline
Just get a copy of the July '04 Chevey Rumble, its got Petes dyno test against a F*rd.
Old 06-08-2004, 08:19 AM
In the June 2004 MuscleCar Enthusiast,Petes 427 Dynoed at 465HP & 426lb-ft of Torque.They bested it one last time by installing headers to reach 508.6HP & 470lb-ft. torque.
MERCY!
Old 06-08-2004, 08:51 AM
Engine dyno or chassis dyno? Through the mufflers? I recall the L-88 numbers I gave were at the flywheel with open headers. Thanks for the replys guys.
Old 06-08-2004, 01:59 PM
Mr 70's is correct. I did build one and tore down in Michigan for the "Certified Stock" thingy. I should have decked the block as it was 40 thousands tall and the pistons ended up sitting in the hole too much! Actual compression when they worked it out was 10:8 to one It was flywheel horsepower, but also on what they call a "sad dyno" as apposed to a happy dyno, meaning, it is conservative. Still was enough to propell the car to 12.0's on more than one occasion on polyglas tires. Heads were NOS and never touched other than a valve job. Pistons were stock TRW units.
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 06-08-2004, 06:54 PM
Sorry, goofed up on which magazine it was, great job Pete.
Old 06-08-2004, 09:19 PM
William William is offline
Bill Porterfield did just this about 15 years ago with a carefully rebuilt engine from ZL1 #26.
All accessories, production 375.7 HP
exhaust manifolds, Camaro
chambered exhaust system,
36 degrees timing
As above with 2-1/8" headers 418.9 HP
replacing the manifolds
Air cleaner, alternator, AIR 447.2 HP
pump removed
Carb re-jetted, timing set 444.2 HP
to 39 degrees
Chambered exhaust system 523.6 HP
removed
Note the chambered exhaust system everybody craves cost almost 80 hp.
http://www.camaros.org/copo.shtml
Old 06-13-2004, 06:44 PM
SMGCO SMGCO is offline
Great point about chambered exhaust. However, I've seen aftermarket stainless systems advertised with 2 1/2 or even 3" mandrel bending that might be o.k.
Old 06-15-2004, 02:46 AM
GMH454 GMH454 is offline
Had the joy of a A/Prod Vette with crate L-88 several years ago. I asked the guy I bought it off about the horsepower and said his engine was built for torque, the engine builder had told him it was 550lbs.
It drove like it, at around 4800-5200 it would break the tyres loose (Big 10" racing wheels). That was not on the gear change but on accelerating up thru the rev range, in third that's around 130mph with a nice twitch just to make sure you are paying attention.
Junior Johnson once said "horsepower sells cars....torque wins races"
When Tonawonda (forgive the spelling ) closed the NCRS did a feature on it and asked the guys there what the L-88s dynoed at, they said around 510hp, on the engine stand.
