Old 08-31-2004, 07:06 AM
Michael4yah Michael4yah is offline
Default Help with 68 396/375 AUTO
A few years ago I bought a 68 SSRS w/o engine, trans, driveshaft, or trans mount. It did have 396 markings, 6K redline tic toc tach that appears original, Big block motor mounts and 12 bolt rear end. The build sheet is gone along with everything in the engine compartment except the steering box and motor mounts. It has front disc brakes and a floor mounted shifter w/ console and guages. The floors look unmolested and so does the dash. I want to restore the car but dont know what engine to use. Some of the books say that 396/375s did not come with turbo 400's. Some leave that out stopping short of not saying they never existed. Is there anyone out there that can give me some advice on what else to look for. For instance is there a tale tell sign somewhere on the tic toc tach that would tell me its a reproduction and not original equiptment? Any advice would be greatly appreciated. Michael SoCal
Old 08-31-2004, 04:51 PM
Default Re: Help with 68 396/375 AUTO
You say it has a floor mounted shifter. Is the shifter still there?
If it is and is a Automatic one, which type is it? ie Horse shoe console type or 67 type non console auto shifter. The 67 type (non console auto) used a hole punched in the floor much like a 4 spd. but then used a shifter plate which was about an 1" high and square with the shift indicator on the left side in a arch that ran front to rear. I have only seen 1 of these ever. They are in the 68 Assm Manual though.
Believe it or not they look like (dare I say) a Pinto or Mustang II auto floor shifter.
Old 08-31-2004, 11:07 PM
In the Ron Sessions book called " How to work and modify the Turbo Hydromatic 400 transmission" on page 12 under Chevrolet it says that there was a 67-68 trans for the 396 Hi.Perf. It had the code CE. Does this mean that there were 396/375 w/ turbo 400's in 68'??
Its a 68 car with what looks to be like a true 68 shifter/console. Its the horseshoe one. Is there any tell take signs that could tell me what 396 engine came with it? I mean its got what looks like an original 6k redline tictoctach and this floor looks original.
Old 09-01-2004, 05:46 PM
If I am not mistaken the only cars with 6000 redlines were solid lifter cars. Which were either the Z28 or the L78.
But Yenko made quite a few 68 Automatic cars. Were they L78 cars with 4 spds to begin with then switched to autos at the dealership? Or were they L34's with autos and then had the L72 Long block put in them.
Old 09-01-2004, 08:02 PM
I think the only 68 396-375 autos were the 50 COPO Nova's Gibb sold. I have never seen any other cars with one. The CE trans I think was for the 350 hp 396. Kim
Jake is my grandson!!
Old 09-01-2004, 08:21 PM
427TJ's Avatar
427TJ 427TJ is offline
The Colvin book lists the application for the '68 Th-400 in Camaros as 396/325 or 350HP. For cross reference the book lists the Camaro 396/375HP as using either the M21 or M22 4-speeds or the Heavy Duty (2.41 first gear) M13 Borg-Warner 3-speed.
