Old 02-10-2005, 09:16 PM
mtuck mtuck is offline
Default Rim and tire size
I have a 67' Camaro that i am restoring. I was wondering if anyone might know if a 17 x 8 rim will fit on the back? I want to keep the rim under the wheel well opening. I have lowered the car two inches in the back. If it will fit, what back space should i use? And what size tire would you recommend?
Thanks for any help
Old 02-10-2005, 10:14 PM
427TJ's Avatar
427TJ 427TJ is offline
Default Re: Rim and tire size
What you should do first is jack the car up, remove the rear wheel(s) and start measuring. Measure the distance from the outer face of the brake drum (where the wheel rests when mounted) to the vertical face of the inner wheelwell. That's the critical number and will guide your backspace decision. Take the tire size you think you're going to use into account too. Tire cross-section could eat-into that distance. Do the math carefully and you'll probably have to measure it a few times while you crunch the numbers.
Another method wold be to mount a wheel with a known backspace and measure from the outer rim edge. Again, factor-in tire cross-section.
Depending on the tire size you could run out of room if rim backspace goes deeper than about 3.75 to 4.0 inches. That's just from my own experience on two of my '67s. Perhaps you can ask a tech guy at a wheel manufacturer and see what his fitment guide says.
