Old 08-04-2005, 11:16 PM
Kacyz28 Kacyz28 is offline
Default 67 firebird 400?s
A used car salesman brought in this 67 firebird that he just purchased.He says its 1 of only a 100 left in existance with a 400,auto,ac,ps,manual brakes,hood tach vynle top.He says it was ordered as a 6 cyl then while it was on the assembly line converted to a 400.I think he got took I have the VIN and all codes from the body by fischer tag can someone point me in the right place to decode this car and if Ill need any other codes
Old 08-04-2005, 11:56 PM
DaJudge DaJudge is offline
Default Re: 67 firebird 400?s
Go to the link below, it's for Pontiac Historical Services. They can give you from microfiche a copy of the actual factory to dealer invoice for the that lists all the options etc. Unfortunately you cannot tell if it's a real 400 car from the factory without running the VIN through PHS, unless the guy has some dealer or factory docs like the window sticker or broadcast sheet.
Production Numbers for 1967 was for a 2 door cpe (22337) 67,032 units , 2 door convertable( 22367) 15,528 units. Out of those 18,635 were 400's. I have owned two 69 TA's with RA III and a 67 400 as well as a 69 400 great cars that run hard and look great. But as you can see in 67 they made 18,000 cars there is most likely more then 100 left. If you are interested in the car you better run the VIN through PHS. The last 8 digits of the VIN number will be on a machined surface on the passenger side of the timing cover. The VIN will also be on the passenger side of the trans if it is a manual and on the drivers side above the pan right by the transmission shifter cable bracket on an automatic.
1967 400 engine codes for all Pontiacs
400 255 HP XL,XM
400 260 HP XB
400 265 HP WA,WB
400 265 HP YA,YB,YC,YD
400 290 HP XV,XU
400 293 HP XC
400 325 HP WU,WZ,WQ,WI
400 325 HP YE,YF,YT,XE,XN,XW,XX
400 333 HP WD,WE,WY,XT
400 335 HP WT,WW,YS
400 350 HP XZ,XY,XH,XJ
400 360 HP WS,WV,WR,XS,YZ,XP
The above engine codes are on the front passenger side of the block below the head. The 400 block casting number for 1967 is 9786133, this is by the distributer at the back of the block.
www.phs-online.com
Hope this helps
<span style="color: blue">1970 GTO Judge Ram Air IV, 4 speed</span>
Old 08-05-2005, 02:50 AM
any way to read codes from the firewall tag
Old 08-05-2005, 04:41 AM
StealthBird StealthBird is offline
This website has a wealth of info. Scroll about halfway down, and you'll see Body Tag FAQ's.
http://firstgenfirebird.org/firebird/FAQ/
If the owner claims it was a 6 banger converted to a 400, be cautious. Once the PHS documentation comes back, and it's shows 6-cylinder, it will be very difficult to ever resell. If it's a driver, that's great, but if you plan on buying it, pay the clone price, not the authentic price.
1959-1980 Pontiac Window Sticker Reproductions : PontiacWindowStickers.com
DVD's for Musclecar fans! MusclecarFilms.com
Old 08-05-2005, 04:43 AM
Sorry, I meant to say "Dataplate FAQ's". Looks like I picked the wrong week to stop sniffing glue.
Old 08-09-2005, 01:51 AM
actually the guy just bought it and told my boss the story and relayed it to me and i dont believe it
