Old 11-21-2005, 09:15 PM
jfkheat jfkheat is offline
Default 427 4 bolt block question
I finally got home long enough to get the 427 I got off Ebay. I think it may be a 2 bolt block that was converted to 4 bolt. How can I tell if it was a 2 bolt block? It is a 512 block with a cast date of Jan 15 1969. The block was decked at one time so there are no numbers on the pad. I can't find any numbers near the oil filter. Exactly where would they be?
Thanks, James
1968 Beaumont SD396
Old 11-21-2005, 09:40 PM
Default Re: 427 4 bolt block question
The 4 bolt blocks should have the two big pipe plugs above the oil filter boss. These were used for an external oil cooler if required.
Old 11-21-2005, 09:54 PM
markjohnson's Avatar
markjohnson markjohnson is online now
Keith is correct. Both pipe plugs above the oil filter will large and of the same size. On a two-bolt main, one of the pipe plugs is smaller than the other.
Old 11-21-2005, 10:14 PM
69L72RS 69L72RS is offline
I thought 2-bolt blocks had 1 fitting for the oil sender
and 4-bolt blocks had one hole for the sender and a second larger hole for the oil cooler line fitting.
I will try to find a picture to post.
Eric
Old 11-21-2005, 10:27 PM
Thanks for the replys. Eric, I will call you shortly. The block has 2 holes by the filter. The one directly above the oil filter is larger that the one that is off to the side.
James
1968 Beaumont SD396
Old 11-21-2005, 10:43 PM
Sounds like a 4-bolt block
Jake is my grandson!!
Old 11-21-2005, 10:08 PM
Hello James
I sent you two PMs.
I have 11 points that I use to check, if a block is suspect of a 2-bolt/4-bolt switch.
They are not absolute checks but they have saved me from buying converted blocks in the past.
Hope this helps.
Later,
Eric
Old 11-21-2005, 10:11 PM
Chevy454 Chevy454 is offline
Good stuff, Eric...mind dropping me the same info via PM?
