Old 06-01-2006, 04:20 PM
1970ChevelleSS 1970ChevelleSS is offline
Default Help! Need some numbers help on a car I am looking
Ok I need your guys help on a car I am looking at. It is a 1969 z-11. Here is what I have.
Build date 03D
Block Pad T0318HA
Tranny P9C18
Axle tube BT 12 06 G2
Brake booster 0-8
Rear end Housing K18
Starter 1108367 8H29
Heads Left 3947041 C59
Heads Right 3947041 C39
Thanks for any help. I know I can look all this up but time is real tight if I am gonna get this.
Old 06-01-2006, 07:42 PM
Default Re: Help! Need some numbers help on a car I am looking
Mark C. is the guy you want to ask about pace cars (with apologies to the other Z11 experts out there - no offense intended).
Having said that, looks like all the dates are plausible for that car. The rear axle seems a little early for a 3D car, but I don't think it is way out of line.
Do you have a picture of the trim tag? That would be my biggest concern on any of the Norwood cars. So many forgeries out there right now.
Lynn Bilodeau
Old 06-01-2006, 08:02 PM
69L72RS 69L72RS is offline
I would agree with you Lynn on the rear.
My 04C Z10 had a 0413 dated rear according to the POP.
The rear is still a good code BT = 3.55 posi.
I think the trans code is missing the last letter (A,B, or C) also??
My car has an HB engine code for the 350/300 auto.
I think the HA code is correct for the 4spd cars.
Also the 041 heads would be the right castings.
Is the block a 386 or a 388 casting?
Mine is a 388.
I'll get the build date off of my block tonight to see how close it is the the car build date.
Eric
Old 06-01-2006, 08:21 PM
block is 388
Mark_C Mark_C is offline
Block should be a 618 casting, probably cast 2 or 3 days before assembly. Cars too late for a 388 casting, and to early for an 010 casting. Muncie case will have an A suffix, since you couldn't get an M21 or M22 transmission in an L48 car. The axle seems to be dated to early for the car (doesn't mean its not the original though) but everything else seems to be correctly dated for a late March built car. Need to see the stamps to see if they are original though.
Mark C.
My Pace Car
Old 06-01-2006, 08:48 PM
tranny does have the A suffix but is the 388 the worng block casting?
Old 06-01-2006, 08:49 PM
block casting is 3932388
Date A-8-9
