Depends on Hp rating, 2 bolt or 4 bolt block, High Performance Solid Lifter, Cast Iron or Aluminum Heads, etc. Please post more info and Pics. Thanks,
Paul
70 Camaro LA Z-28 03B Citrus Green LT-1 M-40 3.73's 69 Camaro X-77 Z-28 10C Cortez Silver M-21 3.73's Deluxe Project X - SOLD 69 Camaro X-77 Z-28 01B Garnet Red w/Black top, M-20 3.73 Deluxe Houndstooth |
Paul,
The motor has 4 bolt mains, forge steel crank. The heads have a 840 casting #.Rods are 3/8 with a dimple on them. |
Can you post the info on the block stamp pad and include a pic if possible. The stamp pad is located on the block under the alternator on 69 models.
Engine assy code = T0619XX June 19th assembly, XX - appl code Paul
My guess on value would be $5000 or more if everything is in good condition. Has the block been bored? What intake? Are you sure it's a crate motor? It could possible be a COPO motor. If so, the value would be a lot more. You have probable already gotten quite a few PMs asking for info.
James
1968 Beaumont SD396 |
Block stamping CE 958752.The motor is standard bore, heads have had no work done to them.Intake # 163.Paul and jfkheat thank you for your time.
