Old 04-10-2007, 04:14 AM
67l78 67l78 is offline
Default distributor part numbers??????
Can anyone help me figure out how to find what stamped numbers are on the vacuum advane unit, cam weight base, the correct mainshaft etc. This would be for a 1111169 for a 67 camaro. I have the original 1111170 for my 67 L78 and know these numbers, I just cant find any info on the 1111169. Thanks!! Travis
Old 04-10-2007, 04:48 AM
Default Re: distributor part numbers??????
I think for your #11111169 Distributor the Vacuum advance unit should be #1115357,if your distributor is stamped before April 1966.
If after April 1966,use Vacuum advance #1116201.
It used:
Main shaft-#1968535
Weights-#1881371
Springs-#1882774
Rotor-#1971247
Base plate-#1962141
Old 04-10-2007, 04:53 AM
427king 427king is offline
Yenko Paid Member
if your distributor is stamped before April 1966...If after April 1966
[/ QUOTE ] 1111169 was not used in 1966, it is a 67 68 part.
Old 04-10-2007, 04:55 AM
Yeah its for a 67 camaro.
Old 04-10-2007, 06:46 AM
Kurt S Kurt S is offline
Advance cam is 732 CCW.
Kurt S - CRG
Old 04-10-2007, 03:32 PM
So its the same (732ccw)as my 1111170? Thats good to know! What about the vacuum advance unit? MS 360 12 is on my 1111170, is this the same on a 1111169? Thanks!
Old 04-10-2007, 07:25 PM
My error,I believe those 4/66 dates are in relation to the Vacuum advance release itself,not the Distributors assembly date.
I just checked an unrestored #1169 from an 1967 L-35 Chevelle and it's holding a 12 degree #1115360 V/Advance.Chevrolet records confirm it too as original equipment,yet Delco records say it used a #201.
I would use the MS 12 #360 for your #1169.
