Old 06-05-2007, 06:28 AM
69L72RS 69L72RS is offline
Default Help with a Chevelle tag decode, please.
I have located a 69 Chevelle that I was told is a real SS car.
Would someone please look this tag info over and let me know if this is a real SS or another wild goose-chase. Below is all the info that I have been able to get from the owner.
I am trying to set up a time to look at it in person this coming weekend.
ST69 13637 BAL254777 BDY4
TR 756 72 B PNT
05D 8 B L179154
The car is in primer and has the following, black bucket seat interior, factory tach and gages, 4-spd muncie, 12-bolt posi, PDB. The engine is supposed to be a 396 out of a Nova.
The body is fairly solid with a few rust holes in the front fenders and drivers door.
What else should I look for?
Thanks in advance for your help.
Eric
Old 06-05-2007, 06:44 AM
Default Re: Help with a Chevelle tag decode, please.
That trim tag says Super Sport.
Original Monaco Orange w/ Black V-Top & Blk Buckets.
What's the redline on the tach?
Relay the rearend prefix stamped on the passenger side axle tube too.
Old 06-05-2007, 06:47 AM
427king 427king is offline
Yenko Paid Member
Eric, Its a BB car because its orange. Id look for a 3/8 fuel line and a 6000 tach to see if its a 375. May want to check the rear ratio .
Old 06-05-2007, 06:54 AM
Thanks for the help guys.
Rick,
I'll get the axle code this weekend.
Chuck,
He said the tach is yellow at 5700 and red at 6000 with a 7000 end. I'll check to see if the ratio matches the code when I look at the car.
Old 06-05-2007, 06:56 AM
Look for a buildsheet behind the passenger side front door panel 1st,then the drivers side,then behind/under all the seats & two rear panels,then the carpet under layment.
Old 06-05-2007, 06:58 AM
Rick,
Do you mean between the door panel and the door shell?
Old 06-05-2007, 07:00 AM
Yep.
