Old 01-23-2008, 07:11 AM
cib12 cib12 is offline
Default 3970010 blocks with December "M" in casting date
Does anyone have and info on the "M" (Dec) casting date on the 010 block.It is in Colvin's Chevrolet by the numbers. Does any one know more about this. My Z-28 has this. Thank you for any response on this.
Old 01-24-2008, 07:16 AM
Kurt S Kurt S is offline
Default Re: 3970010 blocks with December "M" in casting date
Of course.
Very detailed info about M blocks at:
http://www.camaros.org/drivetrain.shtml#BlockCast
And it wasn't a code for December!
Kurt S - CRG
Old 01-24-2008, 09:21 AM
thanks very much to clear this up for me. would you have a pic to see how it should look thanks again
Old 01-24-2008, 03:20 PM
BARRY BARRY is offline
HI yes dec 1970
Barry Allan
Old 01-24-2008, 06:15 PM
From CRG:
"M"-Coded Blocks
"There is one exception to the normal block casting date convention that has been observed: some blocks have been seen with "M" cast codes. Research by the Saginaw Metal Casting Operations of GM Powertrain Division has found that these "M" codes are not date codes, but actually a foundry code used to indentify parts that were made to evaluate a casting process change. After evaluating the parts, the blocks would either be destroyed or released into production. There is no way to determine the date an "M"-coded block was poured".
Old 01-28-2008, 07:22 AM
thanks again for your response Kurt S- could you give me an example of what the m code might look like--is it a m only or could it be (example) m 4 7 or something similar to that thanks again
Old 01-29-2008, 02:52 AM
70 Forest Green Zee's Avatar
As far as I know "L" has always been the date code used for December....example:
1970Camaro Z28
Old 01-29-2008, 09:40 AM
It would be M and a 1 or 2 digit #.
Kurt S - CRG
Old 01-30-2008, 06:35 AM
thank you Kurt
