Old 08-20-2009, 04:36 AM
DarrenX33's Avatar
Default Re: Oil Recommendation/Solid lifter 427
The engine builder that did my L78 told me I can use plain castrol 10-30 with a bottle of Comp Cams cam breakin for every oil change and that would be good enough.
1969 Z28
1972 Corvette
Old 08-20-2009, 04:12 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Is there a source for Valvoline 20W-50 VR1 in Toronto,Canada? Need some for the LS6 after reading this posting. I was using Castrol with GM 'EOS' added.
I ain't nobody, dork.
Old 08-20-2009, 04:44 PM
Try Avenue Motor Works 416-747-2800 and reach Paul,ext 2238.
Most NAPA stores over there carry VR-1 racing oil,but if neither of those pan out,try calling Valvolines Canadian headquartered office at 1-800-286-4292.
Make sure you specify you're looking for VR-1 <u>Racing</u> oil.
Old 08-20-2009, 04:53 PM
Tracker1's Avatar
Will do - thanks!
Old 08-20-2009, 10:20 PM
lzdick lzdick is offline
If you run a high quality zinz oil and add some ZDDP or the Crane or Lucas additive is it possible to have too much zinc in your oil? Whats the best additive Lucas, Crane or ZDDP? Sam
Sam,
Read the TechBriefs on the website. ZDDPlus
TechBriefs #5 &amp; #6 address racing and diesel oils, respectively. TechBrief #7 on 'dosing' and TechBrief #8 on 'market viewpoint'.
It is the only product I use in my Camaros...and have a standing offer to get it to you at less expense than the $9.95 + UPS shipping on the Kirban website. Discounts to all SYC members.
L.Z.
"...at this point in my life, every day is a Saturday".
Old 08-21-2009, 08:36 PM
PaulK PaulK is offline
I have researched this a while ago with the different manufacturers chemists, and the present day (SM) Rotella, Delo400 and VR1 all have the required 1200 ppm zinc (especially for street use). These are a lot less expensive than Brad Penn, although the Brad oil does have more zinc ~1500ppm.
Old 08-21-2009, 08:59 PM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
I run Castrol GTX in my stock ZL-1 w/GM solid cam and lifters and never had a problem. I think the problems are with Chinese made cams and lifters, I only run GM stuff. The cam companies blame the "new" oil when it is their offshore crap that is to blame. I do think it is hype that you have to have high levels of Zinc. If you break-in your cam properly with the inner valve springs removed and lots of cam lube, you should have no problems.
1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 differential, California car, PS, PB, PW, AC, Jetfire 2 option package.
Old 08-22-2009, 02:23 AM
Hey Greg, you may have something there with the Communist parts! Good point.
Old 08-22-2009, 04:41 AM
ss427copo's Avatar
ss427copo ss427copo is offline
Thanks for all the feedback....You guys are the best!
Jeff x 2 1/2
Jersey Jeff
69 Day-2 L89 T400 BX
2015 ZL-1 Auto
98 Surburban
