So I was looking at this '69 and found out that the VIN doesn't match the Cowl Tag.
Vin: 124379N709835 Cowl Tag : 307046 http://cgi.ebay.com/ebaymotors/Chevrolet...5fCarsQ5fTrucks Completely wrong ranges. VIN is a Mid NOV range and the cowl tag is a 01A I bet the car had a 6cylinder VIN, so it was swapped for a V8 VIN. My suggestion is to not buy this car. Run as fast as you can ![]() Tony Huntimer Camaro Performers Magazine |
Actually, if the driver's door is original to the car, then it is probably the tt that was changed, not the vin. Definitely one or the other; possibly both. Need to check the hidden vin's against the one on the dash.
My guess with the wrong brake booster-master cylinder setup and the ten bolt rear end that someone added that Trim Tag. If you had a real SS you would already have the correct brake booster so there would be no need to add what you see on the car now.
This one too:
http://cgi.ebay.com/ebaymotors/Chevrolet...5fCarsQ5fTrucks The VIN (listed) 124379N670533 ![]() The VIN is for 08A 1969, but the trim tag "body sequence number" is an 08A 1968 number. This cheater didn't do their homework. Am I off base here? Tony Huntimer Camaro Performers Magazine |
VIN 124679N692929 is 9E for 69 Body number is 141356 which is 9e for 68 range ![]() ![]() This car has the same issue of 9E tag not matching the VIN. Sorry folks...there were 2 9E tags that year. |
I think this Camaro was built at the extremely rare North Branch, MN plant.
![]() ![]() Tony Huntimer Camaro Performers Magazine |
Nothing wrong here at all. BDY numbers were re-set to 100001 as of VIN N670xxx. VIN is in range for 08A.
I learn something new every day.
![]() I'd like to retract my comments bout those being fakes, but the edit feature says my time has expired. At least you've cleared up the discrepancies, but my first post still stands. Thanks, Tony Huntimer Camaro Performers Magazine |
Was X11 an SS code? I thought that it was just the style trim package that any non-SS car could get. Dash has ac vent, firewall doesn't look like it has the condenser. I'm no expert, but my guess is the trim tag is bogus.
![]() COPO 9561/9737 M40 X11D80 13.37 @ 105.50 on pump gas,drove it to NATL TRAILS and back [email protected] SCR22 |
X11, includes SS350 cars
Thread Tools | |
Display Modes | |
