Old 09-26-2011, 08:09 PM
Fast67VelleN2O's Avatar
Default Parts headed to Carlisle. Lots of good stuff.
1968-1972 Chevelle 4.10 12 bolt posi Rear. Nothing special code. $950.
1968-1972 Chevelle 3.31 12 Bolt Posi Rear. Has ring gear spacer. Nothing special code. $825.
1968-1972 Chevelle Moser 9" Rear End. Aftermarket housing, 3.90 gears, 31 spline axles, traction Lock posi unit. $1300.
1970 Camaro 12 Bolt 3.73 Posi. Coded COZ out of Z28. Richmond gears, posi unit has some marks, nothing major $900.
1969 427 block. 512 casting .030" Dated May of 1969. was decked, no codes or vin. $1800.
1968 427 Block. 321 casting. Out of Corvette L89, Fresh .060", was discussed here on SYC. Car is known. $2200.
1967 327 shortblock. 657 casting, no codes or vin, .030", 11:1 L79 pistons, steel crank. Needs freshening. $600.
Service dated 291 square ports. Have been ported but nothing major. Valves are present but no other hardware. $600.
1970 Chevrolet 454 291 square port heads. No porting. Dated K-28-9 and L-8-9. Nice used heads. No guide plates. $900.
1969 Chevrolet 396 or 427 square port heads. No porting. 3919840 dated C-35-9 and C-27-9. Complete. Good cores. $900.
1971 Camaro Z28 350 block. 3970010 dated C-24-1. Stamped V0326CGP. Vin 11N563805. Standard bore 4 bolt. $675.
Lots more but this is stuff off the top of my head. Spaces G41 and G42.
-Matt
Day 2 is Life.
Old 09-26-2011, 09:26 PM
x77-69z28's Avatar
Default Re: Parts headed to Carlisle. Lots of good stuff.
matt, i will be there on friday. i will stop by.
buddy
Old 09-26-2011, 11:57 PM
More stuff:
1971 Muncie M22. Very nice low mileage unit. No issues whatsoever. Original GM gaskets with the tabs as well. Out of Pontiac. $1500.
1974 GTO Hood and Shaker assembly. Original GM stuff. $750.
NOS 64-66 Mustang quarters, outer wheel houses, and trunk drop offs. All NOS FoMoCo. $1000 for everything.
Small block and big block trap door Corvette oil pans. Small issues but will straighten out easily. $200 each.
461 X heads dated late 1961. Bare. Never been modified ever. $675 pair.
78-81 Corvette glass t-tops. PPG replacements. Very nice. $600 pair.
1962 Chevrolet 409-380hp intake manifold. 678 casting number. No issues. $350.
69-75 Corvette tilt-tele column in silver with steering wheel. $550.
69-72 Chevelle floor shift column. Non tilt. $75.
Lots more. See you there.
Day 2 is Life.
Old 09-27-2011, 02:03 AM
C1SS396 C1SS396 is offline
I'll be set up with fast
1970 Chevelle/El Camino CCF coded(3:31) D 22 70 dated 12 bolt rear complete drum to drum /drums dated D 25 70 has moroso brute strength posi unit in it . $1400 obo
1970 Nova CBS coded (3:31) 12 bolt housing dated L 29 69.Spring perch's have been cut off .But i have a new repo set to go with it ..$450 obo
1970-72 NOS door skin $350
Plus a lot ..
I am out there finding it so you don't have to .
Old 09-27-2011, 02:15 AM
Looks like its going to be rear-a-palooza.
Day 2 is Life.
Old 09-27-2011, 02:20 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Fast67VelleN2O</div><div class="ubbcode-body">Looks like its going to be rear-a-palooza. </div></div> The late Art Houser would be proud .
Old 09-27-2011, 04:32 AM
Nova Jed Nova Jed is offline
Art knew his hind ends! When is Carlisle?
Jed 69,70,71 Nova's 1955 Bel Air and a 69 Camaro.
Old 09-27-2011, 02:16 PM
69L78's Avatar
69L78 69L78 is offline
Jed, Carlisle starts tomorrow Wed the 28th thru Oct. 2nd
Old 09-27-2011, 11:50 PM
Son of A! Thanks Jeff.
Old 09-30-2011, 02:08 PM
Picture of our fast67 spot from yesterday before the storm .Hope its better today.
