Have the following 2 forks, one is NOS, can someone figure out the application?
14066335 (might be 14066235) 03892632 Also, need the best place to obtain a decent throw out bearing, the one that came in the clutch kit looks like junk. Finally, need the best place to obtain the hardware to: bolt trans mount to trans (4speed), trans to crossmember, and crossmember to frame. PS: for search purposes, in case anyone is ever looking for their # matching trans, I have: 29B175169, and it's stamped: P 9E20 A. Not sure what it's out of, thinking a '69 Pontiac?
14066235 shows up as fitting '73 to '81 Camaro and '73 to '77 Chevelle and Monte Carlo and others. Clint
Any reference to BB vs SB?
GM parts wiki shows it in pickups fitting small block and big block. On ebay they don't really say on the ones I read. You can copy and paste the part number in the ebay search and check the completed auctions and see what they sell for.Clint
I don't want to sell 'em, just want to know which one I can use for the '69 big block Nova, and hoping I can use the other one for our small block Camaro!
If you drop the 0 the 3892632 number fits Camaro '67 '68 '69 all engines and most body styles and all v8 engines except some later passenger cars. There are several discussions about what works on Camaro clutches when transmission modifications are made and the cure is usually to use the GM 3892632 fork that may be still available since it was in 2009. I think your 0 prefix is a newer version and doesn't show up in the old books. Clint
Ok, thanks!
I believe AMK has the x member, and trans bolts your looking for.
Thread Tools | |
Display Modes | |
