Old 04-30-2014, 10:55 PM
1969l78 1969l78 is offline
Default Re: 69 Z28, Champagne Gold
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pulnaway</div><div class="ubbcode-body">You can tell by how a Craiglist ad reads if the seller is a squirrel or not. This guy is and he has been watching to much Fast and Loud.
</div></div>
[img]<<GRAEMLIN_URL>>/haha.gif[/img] [img]<<GRAEMLIN_URL>>/haha.gif[/img] [img]<<GRAEMLIN_URL>>/haha.gif[/img]
Old 04-30-2014, 10:57 PM
bkhpah bkhpah is offline
I would love to see this car done...BKH
Old 04-30-2014, 11:01 PM
<span style="font-style: italic">&quot;...He also claims the VIN number has all of the numbers in a clean even row and then the final number in the VIN is a &quot;1&quot; which is slightly lower and spaced further out than the rest of the numbers, which he claims is GM's way of designating a one-off build...&quot;</span>
Is he talking the Vin tag here or original block and trans stampings?
[img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Old 04-30-2014, 11:34 PM
His claim of,&quot;EVERY date code on the car is the exact same day in 1969,which he claims means that is was hand assembled from parts pulled especially for the day it was built&quot;,seems not only ridiculous to me,but literally impossible.
All the window glass dates,engine &amp; electrical components,fuses,seatbelts,hoses,belts,headlights, the frame assembled stamping,sheet metal body panels,dashboard components,carpeting &amp; jute,assembled seats,keylocks,shock absorbers,relays,brake lines,fuel lines,transmisson &amp; rearend internals &amp; anything else I forgot,were all made &amp; assembled the exact same day and then shipped within minutes if not seconds to be put on this particular car?
Does he have any idea of the scope of what he's saying,especially since so many assembly line parts had different manufacturers &amp; batch date periods?....that in itself was impossible,unless they had help from the Mayans.
Old 04-30-2014, 11:40 PM
Is he talking the Vin tag here or original block and trans stampings?</span>
I believe he was referring to the VIN plate on the top of the dash.
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 04-30-2014, 11:44 PM
70 copo 70 copo is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body">His claim of,&quot;EVERY date code on the car is the exact same day in 1969,which he claims means that is was hand assembled from parts pulled especially for the day it was built&quot;,seems not only ridiculous to me,but literally impossible.
Does he have any idea of the scope of what he's saying,especially since so many assembly line parts had different manufacturers &amp; batch date periods?....that in itself was impossible,unless they had help from the Mayans. </div></div>
Rick,
It is pretty obvious that going after the guy on the assembly claims he is making would be about as thrilling as clubbing a baby seal on the beach .
Old 05-01-2014, 12:25 AM
To you,me &amp; most every veteran on here Phil,yes.
I just posted the obvious in hopes he is here,or others who are new here understand it.
Old 05-01-2014, 12:50 AM
resto4u resto4u is offline
if it was stripe delete, it needs paperwork to prove or have - or -- paint code.
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 05-01-2014, 12:59 AM
Yes, stripe delete would require a - - paint code.
He better take that $125k.
Old 05-01-2014, 03:37 AM
69VN's Avatar
69VN 69VN is offline
Has anyone asked him if the previous owner can still be reached? I'm sure there would be a host of questions for him!
SAL
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
