Old 01-09-2017, 11:33 AM
ronzz572 ronzz572 is offline
Default Re: Possible 1970 Yenko Camaro
Cowl tag information may be helpful. It will tell you what it started life as if built in Norwood Ohio. If it has L78 or Z28 on tag.Does it have a factory dash tachometer? 8k or 7k gives clues. Vanuys built cars usually have a build sheet above gas or in or under seat upholstery.would disclose the dealer it was delivered to. Welded rear sway bar brackets. Even the frame mounted motor mounts will give clues. Only factory big block cars and the z28 got a special lower mount to give better hood clearance for the air cleaners. Also you can order the NCRS paper work for dealer information too.
1970 L78 camaro Cortez silver ralley sport under restoration
