#11
Shaun,
Perfect, thanks for the update ![]() Dan
69 300 Deluxe Post Sedan Frost Green 69 SS396 300 Deluxe Post Sedan Lemans Blue SOLD 70 Buick Skylark Post Sedan Gulfstream Blue 70 Buick Skylark Post Sedan Burnished Saddle http://m.youtube.com/watch?v=PM3DE8qI2NY https://m.youtube.com/watch?v=Yn4xEmGypUw |
#12
So it sounds like I need to replace rear control arm bushings.
#13
Oh brother, does this ever sound familiar
![]() I did everything listed here as a possible solution (except replacing the bellhousing), and a whole lot more. Although I am very reluctant to declare that my problem is fixed, it appears that it is. I haven't driven it enough since the last repair attempt was completed, as there have been a few other issues that I have been working on. Even if it is indeed fixed, the bad news is that I am never going to know a definitive cause for the problem....it's a long story ![]() ![]()
Bill Pritchard 73 Camaro RS Z28, L82, M20, C60 |
#14
70TA,
Perhaps a little more background on the car would be helpful. Is this a problem that cropped up all of a sudden, or is it something that slowly got worse over time? Any changes made to the car just before the problem started?
#15
Is there an actual shudder w/ clutching action or just a noise? Was the problem there immediately after parts replacement or how long after did it appear? Fork and trans input shaft both inspected and Ok also absolutely no leaking oil or gear lube? What were the face surfaces of FW + PP + Disc both sides also Pilot upon inspection each time apart? Was the replacement flywheel brand new or resurfaced used? I didn't see a release brg. on your parts list but expect it's new too? Don't discount misalignment possibilities and best check detail dimensions also runout of FW and trans input when apart next. Good luck! ![]() ~ Pete .
Thread Tools | |
Display Modes | |
