Old 04-20-2017, 12:12 AM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Originally Posted by Ryan1969Chevelle View Post
I have seen lots of people use A-Body frames as they interchange so mounts should work on the frame.
Ryan
PS: You may get a rash installing a Chevy in an Olds. :-)
I've seen plenty on the Olds sites. They remind me of the Mopar guys lol. Very territorial... I'm thinking a 700R4 and the 454 should pretty much slide in. Maybe extend a couple wires for alt. that's on a different side possibly. Driveshaft might be an issue too.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 04-20-2017, 01:21 AM
Ryan1969Chevelle's Avatar
I agree.
I was all Chevy till Dr Olds arrived:-)
Ryan
Old 04-20-2017, 01:39 AM
earntaz earntaz is offline
Dave -- been there ... done that. You'll need to move the trans crossmember back as the 700's mount is further to the rear. The driveshaft will need to be shortened. Use same year Chevelle frame adapters for the motor mounts. TAZ
Old 04-20-2017, 01:58 AM
You'll have the fastest '69 Cutlass in town
Old 04-20-2017, 12:11 PM
HawkX66's Avatar
The driveshaft will end up being a pain I think. I haven't got the foggiest idea where to have that done around here. I'm not too far from Detroit and Toledo though, so I'm sure there is something out one of those ways. I'll have to take some measurements once I get everything bolted in. When you moved the trans mount, was it a simple, "drill four new holes" or was it more involved than that? Modify the crossmember?
Now you wouldn't be saying the Olds motor isn't up to snuff against a BBC now would you? Here come the Olds die hards with their pitchforks!
I probably would have just rebuilt the 350 Olds he has, it's plenty for his needs, but it's like 2-3 times the cost of a Chevy. Not worth it in my book.
-Dave
Semper Fi!
Old 04-20-2017, 05:59 PM
[QUOTE=HawkX66;1349946]The driveshaft will end up being a pain I think. I haven't got the foggiest idea where to have that done around here. I'm not too far from Detroit and Toledo though, so I'm sure there is something out one of those ways. I'll have to take some measurements once I get everything bolted in. When you moved the trans mount, was it a simple, "drill four new holes" or was it more involved than that? Modify the crossmember?
You'll have to look at the frame -- some will let you slide the crossmember back and drill new holes ... others you will need to mod the crossmember itself. I'm sure if you go to the Chevelle site those troops will chime in. TAZ
Old 04-20-2017, 06:48 PM
HawkX66's Avatar
[QUOTE=earntaz;1349991]
Sounds good. Thanks.
-Dave
Semper Fi!
Old 04-21-2017, 02:07 AM
ZiggyL78's Avatar
ZiggyL78 ZiggyL78 is offline
Everything from a Chevelle fits including headers.I put a 502 crate motor in my 442.As a side note.I don't open my hood at the cruises anymore.I'm tired of arguing with Olds diehards.
Real Canadian Rock
https://www.youtube.com/watch?v=Zdeo-i6uw5g
Old 04-21-2017, 12:22 PM
DW31S's Avatar
DW31S DW31S is offline
Bring it down to Baltimore and find out. No real challenge, but I'll take a spin........
