Old 05-17-2019, 12:18 AM
dlv4540 dlv4540 is offline
Default 1970 396-375HP Engine
1970 396 4 bolt block casting number 3969854 dated H-20-9 and stamped 10W121978 T0822CKO. The block is .030 over from the factory and had it cleaned and magged and found a crack in cylinder #5 & #7 so had sleeves installed and pressure tested. The block has all new brass freeze plugs installed. I have the original 3964291 square port heads dated F-6-9 and F-18-9 cleaned and magged and come with a complete set of guts to rebuild. I also have a 6223 steel crank turned .010 under that will just need polished. Factory 11 to 1 pistons with 6 original and two replaced and have 5 dimple and 3 non dimple rods. 8 inch harmonic factory correct balancer with bolt and washer for crankshaft. I will sell this whole engine for $3500 shipped. I also have some smalls for it like a new set of ac delco R43 plugs, 5 quarts of penzoil 10W 40, high volume deep oil pump, ac PF 25 original blue oil filter, new in the box blue streak rotor and cap and new in the box ac delco 195 degree thermostat.
330-770-2517 for any questions and can provide pictures with a email address or phone number.
Dennis Vugrinovich
Old 05-23-2019, 07:50 PM
bump
Dennis Vugrinovich
Old 05-23-2019, 09:54 PM
JRSully JRSully is offline
Very early Nova L78 engine
71 Porsche 911 Targa
