#991
![]() Quote:
Side terminal battery I just Velcro the top on to a modern battery. Top post batteries takes a little more time as you have to cut those poles away first and free up the plastic around them using a small dremel bit to dig around the edges of the poles. Keep in mind the batteries were DEAD before I started. Maybe after you empty the Acid it will loose it's Power or actually use the battery some how to kill the power ?
"NOSTALGIA It takes us to a place were we ache to go again" |
The Following User Says Thank You to XXXGoldL34M20 For This Useful Post: | ||
Dave Miller (03-30-2021) |
#992
![]() Quote:
#993
The problem is that this is an AGM battery with the gel-coated plates and does not use liquid acid so there’s no way to pour out the acid.
#994
![]() Quote:
Sure isn't any OSHA regs over in that place. Truly frightening indeed. And when he dips his bare hand holding a cut-off soda bottle, into the blue barrel of sulphuric acid to fill the battery - now that's exciting!!! Last edited by njsteve; 03-30-2021 at 06:35 PM. |
#995
You can put baking soda in an acid proof plastic drain pan, then pour the acid in.
I mix baking soda and water, then fill the battery back up with that solution. Now all the acid is neutralized. I have a thread on this somewhere in the last couple years. Put a Braille battery inside my old battery. Works great.
#996
#997
Hook a headlight bulb to the battery and let it sit until there's no more juice left in it. Might take a day or two.... or less?
...................... John Brown This isn't rocket surgery..... |
#998
Well the Lucky Horseshoe have been at work overtime...
After I had the episode with Fedex smashing the last known repro AGM Group 27 battery in existence, I told my buddy Al who owns the local old-timer garage where we all hang out at. He promptly tilts his head, looks up (which means he is reviewing his internal inventory of junk he has never thrown out) and then walks over the the corner of his garage and pulls out an NOS 2444607 Group 27 Mopar replacement battery from 1973 that he has had sitting in the corner cabinet under a pile of alternators since 1973. This is the exact part number for the 1970 battery for a 1970 Cuda, although a dealer replacement part since the later style had the dual three-vent caps instead of the single red verticle venting caps. He called the local Napa store and they brought over a carton of battery electrolyte and we filled it up. It initially only read 6 volts but after the charger went through the de-sulfating process it is currently charging and holding 12+ volts. We stopped the charger for the day and he will hook it back up on Monday to let it run the full charging cycle for a new battery. How's that for happy Saturday? Last edited by njsteve; 04-04-2021 at 03:40 PM. |
The Following 7 Users Say Thank You to njsteve For This Useful Post: | ||
427TJ (04-07-2021), big gear head (04-04-2021), CTBob (04-07-2021), L_e_e (04-04-2021), PeteLeathersac (04-04-2021), RPOLS3 (04-04-2021), Tenney (04-04-2021) |
#999
It was meant to be!
#1000
Crazy stuff just like the 70's again...Purple cars and now w/ the Acid. ![]() ![]() ~ Pete .
Thread Tools | |
Display Modes | |
