#11
https://www.youtube.com/watch?v=EY7_7uey1ac copy everything after the = Then paste that on your post, highlight it and press the You Tube icon - must be in advanced edit to get to it. Presto: |
The Following User Says Thank You to Lee Stewart For This Useful Post: | ||
hogdaddy (06-08-2021) |
#12
Installing an embedder is the way to go, I still can’t get it to work.
#13
Muriatic WILL etch the metal. It needs to be diluted a lot to be safe for the metal and then it works much slower than his results.
If you are going to use it, have a large enough tub to submerge the entire piece to avoid etch lines like I got soaking my fenders one side at a time. The etch will be uniform and if rough enough, supply the "tooth" primers want to grab the metal (substrate) That would eliminate needing to hand sand with 80 grit.
#14
Muriatic Acid is a wonderful thing.
#15
Do this: On the main screen choose "UserCP" (User Control Panel) Then Choose "Edit Options" To make your message screen look like this... Go to the very bottom of the Edit Options screen and choose "Enhanced Interface - Full WYSIWYG Editing" then save the changes. You should be good to go! __________________
Bruce Choose Life-Donate! |
The Following User Says Thank You to Xplantdad For This Useful Post: | ||
#18
I didn't watch the whole thing, cause I can't stand all the hype and BS. If it is already diluted, it may be fine, but don't leave it unattended for long...keep checking it often and remove as soon as it is clean.
#19
I would never use Muriatic acid on stamped steel panels, especially if there are any welded joints (such as at the bottom of this front valance. You will likely end up with paint bubbles a couple years after paint is applied.
JMHO that it is not worth the risk.
#20
I have used it (full strength) previously on cocktail shakers years ago and primed and painted them afterwards with no issues to this day.
Thread Tools | |
Display Modes | |
