Old 07-05-2021, 04:44 PM
ALLZS ALLZS is offline
Default Survivor
ok so I bought a unrestored survivor if I pull the engine to replace the timing chain is it still considered a true survivor the nylon timing components scare the hell out off me
Attachments - The Supercar Registry DSCN7225.JPG 8585EFBA-F003-48F8-B07E-8E982A2315D2.jpeg 1968 z28 4.jpg 1968 z28 3.jpg
Old 07-05-2021, 05:08 PM
Replacing normal wear items is completely acceptable but resist the temptation to "fluff" the engine compartment while you're doing it. What kind of car did you get? Everyone will want to see pics too!
The Following 2 Users Say Thank You to carnut4life For This Useful Post:
m22mike (07-27-2021), Tidmack (07-09-2021)
Old 07-05-2021, 05:41 PM
wundercluck wundercluck is offline
Pics!!!
Old 07-05-2021, 07:55 PM
60sStuff's Avatar
60sStuff 60sStuff is offline
Yes, those OEM camshaft gear nylon teeth are scary.
As stated above, don’t disturb what’s left of any factory paint on that cover when you do the R/R on the chain unit.
What model, year and mileage is on this Survivor car you have?
L78M22Rag (07-06-2021)
Old 07-05-2021, 08:16 PM
Default susvivor
its a 68 z 57000 miles I will post pictures of the gear when I get it out, was not going to not pull the engine but I think that is the best way to do it
The Following 6 Users Say Thank You to ALLZS For This Useful Post:
60sStuff (07-05-2021), 67since67 (07-05-2021), 69M22Z (07-05-2021), PeteLeathersac (07-05-2021), Too Many Projects (07-06-2021), Xplantdad (07-06-2021)
Old 07-05-2021, 08:52 PM
X66 714's Avatar
X66 714 X66 714 is offline
Is that Corvette bronze?...Joe
Old 07-05-2021, 09:39 PM
69M22Z 69M22Z is online now
Thumbs up
Very cool car
Old 07-05-2021, 10:23 PM
You can do a chain/gear change in the vehicle but getting the front cover back on with the pan installed is a MAJOR PITA and the front pan seal/gasket will likely leak. Pulling the pan along with the cover is the only way to get everything clean and leak free.
60sStuff (07-05-2021), Bill Pritchard (07-05-2021)
Old 07-05-2021, 10:56 PM
67since67's Avatar
Awesome find!! As others have said, no paint or fluffing!!
When I was young this was a routine job in the dealership, on any small or big block.
Two approaches,
1. Crack the pan bolts loose except at the rear, carefully leverage the pan down far enough to R&R the cover. Re-use the front pan seal with some discreet sealer, a little more at the corners.
2. Don't loosen the pan, pry the cover off, trim the corners off the inner cover pan seal channel (I know!! ). Use original pan front seal and discreet use of sealer. Use a drift punch on each side to leverage cover back into place.
If done properly, no leaks. Use OEM or black cover gasket, NOT a blue Fel-Pro!
Bill W
The Following 2 Users Say Thank You to 67since67 For This Useful Post:
60sStuff (07-05-2021), PeteLeathersac (07-06-2021)
60sStuff's Avatar
It would be wise anyway to pull the pan to clean any remnants of nylon that may compromise the oil pump.
Looking forward to seeing this Survivor front to back.
Too Many Projects (07-05-2021)
