Old 01-12-2022, 12:31 AM
L_e_e's Avatar
L_e_e L_e_e is offline
Originally Posted by Tracker1 View Post
Great '68! Nice job. FYI I cannot find that Eagle One Mitt anywhere, any links appreciated.
https://www.ebay.com/itm/304256732201
And I use it with Meguiar's Quick Detailer
https://www.ebay.com/itm/282778175253
The Following User Says Thank You to L_e_e For This Useful Post:
dykstra (03-09-2022)
  #62
Old 01-12-2022, 09:07 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Small updates. Been too cold to get out in the garage for very long here but started on bolts, screws etc of cleaning and preserving.
Process is as follows:
I’ve setup several small plastic containers. First one is citrus degreaser to soak the bolts etc. pull them and clean them with a blue scotchbrite pad and dry off. Then into 1st container of evapo. Sit for 24hrs, pull out clean again using the evapo as the cleaner along with blue scotchbrite pad then into another container of evapo and wait another 24hrs. After that pull out towel dry then use PB Blaster silicone lubricant.
Photo 212 - 213 - Hardware as found. At least it was bagged and tagged back in the late 70’s early 80’s.
Photos 214 - 215 - 1st rd of hardware after cleaning.
Photo 216 - 217 - Sunvisors after cleaning. Forgot to snag a before.
The Following 7 Users Say Thank You to cook_dw For This Useful Post:
1967Z28 (01-13-2022), Chuck_Burg (03-08-2022), dykstra (03-08-2022), jbtech (01-14-2022), olredalert (03-08-2022), RPOLS3 (01-13-2022), X66 714 (03-08-2022)
  #63
Old 01-12-2022, 10:06 PM
napa68 napa68 is offline
Niiiicce!
Old 03-08-2022, 12:43 PM
cook_dw's Avatar
Not much going on here on the preservation front but I was able to snag a correctly dated jack assembly and an original trunk mat.
Photo 218 - Trunk mat
Photo 219 - 220 - Jack assembly
The Following 3 Users Say Thank You to cook_dw For This Useful Post:
dykstra (03-08-2022), olredalert (03-08-2022), X66 714 (03-08-2022)
  #65
Old 03-08-2022, 03:52 PM
jbtech's Avatar
jbtech jbtech is offline
I'm going to study this thread over and over to clean my car up. Thanks for sharing.
Jose Betancourt
67 Camaro L78
The Following 2 Users Say Thank You to jbtech For This Useful Post:
cook_dw (03-08-2022), KLars1 (03-19-2022)
  #66
Old 03-23-2022, 11:51 AM
cook_dw's Avatar
Starting the long and slow process of the undercarriage cleaning. Be prepared to be underwhelmed with photos of dirty and then clean floorpans.
Photo 221 - 222 - Before Cleaning
Photo 223 - 224 - After 3rd Pass
Photo 225 - 228 - After 5th pass across area
As I said this will be a slow moving train down the tracks so I probably wont post much if any until I get the full mid section completed. And yes the plan is to pull the subframe, springs and diff out of the car but that will have to wait until I can pull the front sheetmetal as well.
The Following 8 Users Say Thank You to cook_dw For This Useful Post:
1967Z28 (03-23-2022), Chuck_Burg (03-23-2022), dykstra (03-30-2022), jbtech (03-23-2022), L78_Nova (03-23-2022), napa68 (03-23-2022), NorCam (03-23-2022), X66 714 (03-23-2022)
  #67
Old 03-23-2022, 12:46 PM
X66 714's Avatar
X66 714 X66 714 is offline
That looks great. What are you cleaning it with?...Joe
Old 03-23-2022, 01:13 PM
cook_dw's Avatar
Thanks, Zep citrus degreaser with a blue Scotchbrite pad and then wiping with cheapy microfiber rags and then hitting it with #7 Meguiars.
  #69
Old 03-23-2022, 01:48 PM
You're taking good care of my next project Darrell. I want to thank you for that.
In all seriousness...nice work and good progress too.
Old 03-23-2022, 03:52 PM
cook_dw's Avatar
Thanks. Don't hold your breath..
