Old 09-15-2022, 01:32 PM
X66 714's Avatar
X66 714 X66 714 is online now
Default Freeze plug problems
I noticed I had a coolant leak under my ss396 Camaro that I just had at MCACN in November. I didn't rebuild the engine because it only had 41k on the rebuild. I did change all the freeze plugs because I had one leaking. I used the green coolant 50/50 mix with tap water. I've probably only driven the car 3-400 miles since the restoration. I now have three freeze plugs leaking. The one pictured is one I just removed. These were brand new less than a year ago. The battery is never left connected when in the garage.
I sent this picture to my friend Larry (lbnaz) & he indicates that it's most likely a ground problem causing electrolysis. I guess I need to check my grounds but I wanted to ask if anybody has seen this & maybe, where was the problem found?
Thank you, Joe
Attachments - The Supercar Registry freeze plug.JPG CD7EE669-BAE3-478B-88AD-60EAFDD299A9.jpg
Old 09-15-2022, 01:40 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
I always use distilled water when I mix with new green anti-freeze. Too much crud in the tap water here. Maybe the stuff in the tap water is reacting?
Jake Dykstra
Dykstra Motorsports
X66 714 (09-15-2022)
Old 09-15-2022, 01:48 PM
X66 714's Avatar
It never has before but once I resolve the problem I'll change everything out. I will have the old stuff tested that I pulled out....thank, Joe
Old 09-15-2022, 03:13 PM
William William is offline
Possibly, the freeze plugs have become a sacrificial anode. Brass or stainless-steel plugs may solve the problem.
https://www.corrosionpedia.com/defin...rificial-anode
The Following User Says Thank You to William For This Useful Post:
Old 09-15-2022, 09:54 PM
juliosz's Avatar
juliosz juliosz is online now
What he said.
Old 09-15-2022, 03:24 PM
ban617 ban617 is offline
Seems like all my engines have brass freeze plugs …
Old 09-15-2022, 03:45 PM
X66 714's Avatar
Normally that's what I do except I was going for as close to original as possible. Do you know how hard it is to find 1-3/4 steel freeze plugs without writing all over them? Not fun....Joe
Old 09-15-2022, 07:48 PM
X66 714's Avatar
I just dropped off a coolant sample to Caterpillar. They will send it to a lab & I should get results back next week. 20 bucks (cheap) for lab work but I can't lose that engine. i'll keep checking for ground issues....Joe
Xplantdad (09-16-2022)
Old 09-15-2022, 09:37 PM
----All my marine engines have brass freeze plugs, even if the boats are in fresh water. My incoming water is super purified (even de-ionized) before it goes anywhere in the house or garage, so no problem there!.....Bill S
Old 09-17-2022, 12:09 AM
ScottG's Avatar
ScottG ScottG is offline
Your coolant that is now in the engine will need to be fully flushed out , it is probably highly out of the PH range. Does your shifter cable seem to hard to move? If it is a bad ground it will try to use it as an alternative.
1971 Boss 351 , 17,000 miles .. 1971 Buick GS455 .. 2003 SVT Cobra .. 1971 GTO .. 1969 Camaro Fathom Green .. 1969 Camaro Hugger Orange .. 1970 Buick GS455 .. 1970 BUICK GS350 .. 1998 SVT Cobra 1900 miles;. 1973 STAGE 1 GS . 1971 Mach 1 351C 4 speed , first car. 1970 Mach 1 428 SCJ . 1970 SS 350 Camaro . 1971 442 ... 1968 Buick GS400 . 2015 Lexus IS 350 F Sport 2021 Badlands Bronco Sport
The Following User Says Thank You to ScottG For This Useful Post:
X66 714 (09-17-2022)
