#11
Mike (rszmjt) is your best source for the measurements on those second design mounts as I have the first design (and they're now installed on the car). Lloyd.[/QUOTE] Thanks Lloyd! Im going to ask your unanswered question here from the CRG thread 1. Length of the through bolt 2. Diameter and thickness of the flat washer (it appears to be extra thick) 3. Inside and outside diameters of the bright sleeve that passes through the motor mount stop bracket (best view is the first photo) my car is a Sept 69 built car
69 RS/Z 302 VE3 Daytona 69 Chevelle SS 396 375 69 T/A clone LS6/6 speed 90 Formula 350 |
#12
OK, I found them , had to dig through quite a few big totes as they were in storage, sorry for the delay.
Thick washer - 1.380 OD - .187 thick Spacer - .875 OD - .565 thick Through bolt is - 4.450 bolt length underhead to tip TR head marking with 6 slashes. Hope that helps. Cheers. Mike |
The Following User Says Thank You to rszmjt For This Useful Post: | ||
X66 714 (10-14-2022) |
#13
Thread Tools | |
Display Modes | |
