#151
Not suggesting this for you, I'm sure I'd just be happy with the new cap, but someone could just plug a t fitting in the bypass hose and check pressure.
The Following User Says Thank You to jer For This Useful Post: | ||
Arrowsmith (09-17-2023) |
#152
![]() Quote:
I can't use it for my car because I don't use a bypass hose (no machined port in the intake). I use a drilled thermostat from Stewart. That part works great. |
#153
I also have a Stewart thermostat as well as a Stewart water pump. I don't remember what temp the stat is.
1968 Beaumont SD396 |
The Following User Says Thank You to 427.060 For This Useful Post: | ||
#154
Hey Wayne, I've decided to install subframe connectors, as you did, on my Nova. Without looking first, did you encounter a problem with the parking brake cables??
I ain't as good as I once was, but I'm as good once as I ever was. |
The Following User Says Thank You to '69Novajoe For This Useful Post: | ||
Xplantdad (11-09-2023) |
#155
![]() Quote:
![]() Last edited by Arrowsmith; 11-09-2023 at 06:50 PM. |
The Following 2 Users Say Thank You to Arrowsmith For This Useful Post: | ||
'69Novajoe (11-10-2023), Xplantdad (11-09-2023) |
#156
Thanks for that Wayne!! Also, where were you able to source the stainless parking brake cables??
#157
IIRC, they came from Inline Tube.
#158
Hey Wayne, another quick question. I know you used different a-arms than what I'm using, but I'm encountering a "problem" and was wondering if you had the same issue. I'm using Global West, both upper and lower arms. The upper ones don't have a location (or threaded "bung"?) for the brake line bracket to hold the flexible line like the stock arms do. And the lower arms don't have any kind of steering stop like the stock ones do. Did yours come with those "provisions" and, if not, how did you address them?
#159
Hi Joe. I have Detroit Speed uppers and lowers in the car. They do not have a provision to clamp the brake hose, but when I built the car I ran the suspension on both sides through full travel and checked the steering lock to lock at the same time. I’m confident the hoses will not be caught anywhere during suspension travel or when turning.
As far as the steering stops are concerned, I have them, so I can’t comment. Plenty of aftermarket an arms do not have steering stops. My blue Nova didn’t have stops (TRZ a arms). The guy who bought it is still delighted with the entire car, so you can take it from there ![]() Good luck with the build and if you have any questions, fire away. I’ll answer if I can. |
The Following User Says Thank You to Arrowsmith For This Useful Post: | ||
'69Novajoe (04-02-2024) |
#160
Hi Wayne, just thought of another question. I will probably be buying some new rear axles and will also be needing longer wheel lug studs, since now there are no threads coming through the stock lug nuts!! I know they come in all different lengths but I didn't want to get them too long because I'm concerned they might hit the hub caps!! I'm going with the stock caps just like you have. So, my question is, what length studs did you go with?
Thanks again for all your help! Joe
Thread Tools | |
Display Modes | |
