Old 08-03-2024, 01:11 PM
To further complicate the 4P, pass around, code, it was used on early Z28 cars and later for L30/M20, 327 cars...
From CRG
The 4P code was not used at the start of production at either the Van Nuys plant or the Norwood plant.
Van Nuys started using the 4P code on the SS350 cars in September, but Norwood didn't start using the 4P code until October. Early Van Nuys SS350 cars and Norwood SS350 cars built before October will not have the 4P code to verify that they are SS's.
The 4P code can indicate either a SS350 or a L30/M20. Usage of the 4P code with the L30/M20 is believed to have started in the late December 1966 / January 1967 timeframe.
The very first 1967 Z28's and L78's were also coded 4P; the 4L and 4K codes were then used on the remainder of 1967 Z28 and L78 production.
The lack of a 4P, 4L, 4N, or 4K code indicates the car originally had a 327 (assuming the car had a V8, as indicated by the VIN). The only exception is the early SS350's noted above.
1967 4K (08-03-2024), John (08-04-2024), olredalert (08-03-2024)
  #22
Old 08-03-2024, 05:47 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
Default 4P Hmmm 🤔
I didn’t know the 4P was used on that many different engine combinations. Hmmm 🤔.
Richard
1967 Camaro SS 396/375 4K
Old 08-05-2024, 06:39 PM
Sean Sean is offline
I did not know the P code was used always thought it was 4k only. Appreciate the knowledge and information. TY!!
70 LS 6 4 SPEED CHEVELLE
69 SS 396/375 HP 4 SPEED CHEVELLE
68 SS 396 CHEVELLE SS 396/375 4 SPEED
69 COPO CHEVELLE 4 SPEED #S MATCH
69 COPO CAMARO #S MATCH SURVIVOR (BLACK)
69 COPO CAMARO (BLACK)
55 GASSER L88 4 SPEED
66 NOVA "UNDER CONSTRUCTION"
70 440 SIX PAK CHALLENGER SUPER STOCKER
2001 RVW/LDR TRANS AM 1020" BBC 8 SYSTEMS
Old 08-07-2024, 05:53 AM
Kurt S Kurt S is offline
Realize that there are only about 6 4P / L78 cars known.
Kurt S - CRG
The Following 3 Users Say Thank You to Kurt S For This Useful Post:
1967 4K (08-07-2024), dykstra (08-07-2024), John (08-07-2024)
  #25
Old 08-10-2024, 03:39 PM
Default 4P
That is insane had no idea!!! I really appreciate all the info and what to look for and if and when I find a real L78. Sean
