Old 08-26-2024, 07:42 PM
Ryan1969Chevelle's Avatar
Originally Posted by 83hurstguy View Post
I tow with a 2010 Express 3500, has L96, 6 speed, 3.42 rear. I have 75k miles on it now - the engine piston slaps cold, it's susceptible to breaking off exhaust manifold bolts, but the core engine itself has been great. I just changed oil and it hadn't burned any over the last 3k miles; trans fluid was changed around 55k with GM stuff, fluid is still clean.
Tows open trailer with car (5000 lb) like nothing is back there and rides great, probably gets 11-12 mpg on highway with the open, more like 15-16 mpg no trailer. Once I went to a 24 ft enclosed (probably towing between 8-9k), it did okay, if you were pulling up hills you just had to get used to hearing RPM, and it would get right around 8.0 mpg. Since I don't have a great rear gear ratio for towing like the pickups, I just lock it in 5th gear and let it kick down to 4th or 3rd when needed.
Best change I made was getting it professionally tuned - in the vans, GM never let it go into power enrichment mode (had it effectively locked out) so it was always trying to pull at stoichiometric (14.7:1ish), the torque converter locked in every gear (tuner disabled for gears 1-4), and the timing tables were really soft based on intake air temp, so it was effectively always pulling timing. It feels like it picked up 30-40 lb-ft from the tuning, pulls hills way better, acceleration is great, and now I'm getting just a tick over 9 mpg towing the exact same route with the same trailer at 70ish mph. I do typically use premium fuel due to the tune (don't need it around town unloaded), but it's worth it due to the power and economy.
The sad part is that the rest of the truck will have issues with everything else (wiring, accessories, evaporative emissions control system, rust) long before the powertrain gives up.
Very interesting!!
Where did you get the tune done?
Do they have a 94 octane tune and 91 octane version?
Ryan W31
Old 08-27-2024, 07:28 PM
83hurstguy 83hurstguy is offline
Originally Posted by Ryan1969Chevelle View Post
Very interesting!!
Ryan W31
I used a local tuner that is very good (finish line performance) - it was a 6-8 month wait to get in and I had to bring the whole van. He adjusted parameters and test drove it around to assess the impact of the changes. I asked him about multiple tunes, but he basically said it wasn't worth it, just use the 91 octane when towing. We had 87 in the tank when he tuned it (no trailer) and couldn't get it to ping under load. He said I could try the 87 and see if it pings, but I didn't want to take the risk.
'68 H/O W45
'70 Cuda
The Following User Says Thank You to 83hurstguy For This Useful Post:
Ryan1969Chevelle (08-27-2024)
