I swapped out the belt for a parts store US made replacement that had the least amount of labels printed on the belt. Took the car out today and everything works as it should!
I parked the car in the garage, shut off the lights which left the garage opener light the only one on and thought it really brought out the stinger hood. So I present to you Stinger Hood Saturday! |
The Following 14 Users Say Thank You to jbtech For This Useful Post: | ||
1967 4K (09-08-2024), 69M22Z (09-08-2024), big gear head (09-08-2024), carnut4life (09-08-2024), Chuck_Burg (09-09-2024), dykstra (09-08-2024), gtomike1967 (09-08-2024), Hawkeye (09-08-2024), L_e_e (09-14-2024), napa68 (09-08-2024), olredalert (09-08-2024), ragtop (09-08-2024), SuperNovaSS (09-08-2024), Zman1969 (09-12-2024) |
Cool photos. Stinger hood looks great in that amount of light.
What brand belt did you buy? What store? Thanks, Marty |
![]() Quote:
MasterPro 7555 O'Reilly Auto Parts It is made in the USA and they had it in stock. The logos are printed on and can be removed |
Cooling system update
I noticed some coolant on the front passenger floor mat and assumed the worst. After running a pressure test I noticed the heater core wasn't leaking but coolant was seeping past the hoses as the heater core tubes were dented and not providing the best seal. I decided to temporarily bypass the heater core. During the pressure test I noticed an ever so slight tiny bubbling at the front LH water port at the intake when the pressure test reached 14psi. I decided to use the GM cooling system tablets and it solved the problem. I also didn't have a great seal at both ends of the upper radiator hose but opted to replace it as the alternater belt had dug into the hose under hard acceleration. I also ran a pressure test on the original RC-15 radiator cap and noticed it would "open" anywhere betweem 7 and 11psi so I bought a new Moroso cap that tested perfectly at 15psi to run for now. I drove the car to work and told my buddy to bring his Z. I think we had the coolest cars in the staff lot! During the morning commute the temp held steady at 190-195. On the way home in the afternoon stop and go traffic on 101 the outside temps passing through Gilroy were around 105F. My commute in the traffic and heat was over and hour and the temp held steady between 195-210 with zero leaks and no coolant went into the overflow tank as it had previously at lower temps. I'm using a 195 degree Robert Shaw thermostat, original gm fan, original gm shroud, replacement standard duty fan clutch hayden 2713, and an aluminum radiator 2 core 1.25" tubes exact fit painted Eastwood rad black. I'm considering buying the heavy duty fan clutch that locks up a bit sooner to keep temps closer to 190 but my current setup seems to work just fine. Last edited by jbtech; 10-06-2024 at 04:05 AM. |
The Following 11 Users Say Thank You to jbtech For This Useful Post: | ||
big gear head (10-06-2024), BJCHEV396 (10-08-2024), dykstra (10-06-2024), Hawkeye (10-06-2024), olredalert (10-06-2024), PeteLeathersac (10-06-2024), Roger M (10-06-2024), RPOLS3 (10-26-2024), scuncio (10-06-2024), Steve Shauger (10-06-2024), SuperNovaSS (10-06-2024) |
He does! It’s a 4 speed manual
Dave Dykstra 1968 Camaro Palomino Ivory/Ivy Gold interior -Delivered to Courtesy Chevrolet, Los Angeles, CA 2013 Corvette Grand Sport 60th Anniversary Edition Arctic White/Diamond Blue interior -Delivered to Bill Jacobs Chevrolet, Joliet, IL NCRS#66003 Speed has never killed anyone. Suddenly becoming stationary, that’s what gets you. – Jeremy Clarkson. Dykstra Motorsports |
The Following 5 Users Say Thank You to dykstra For This Useful Post: | ||
jbtech (10-24-2024), L_e_e (10-07-2024), markinnaples (10-30-2024), olredalert (10-07-2024), PeteLeathersac (10-07-2024) |
good one. my 26 year old son has a brand new supra. never learned. im teaching him on my 70 5 speed monte.
The Following 3 Users Say Thank You to luzl78 For This Useful Post: | ||
I was thinking the same thing.It's the nicest and most desirable car in the parking lot in my estimation!
https://www.youtube.com/watch?v=gkDf7PPRzJ0 |
The Following 3 Users Say Thank You to BJCHEV396 For This Useful Post: | ||
Tags |
1967, 396 ss, l78 camaro |
Thread Tools | |
Display Modes | |
