Old 11-11-2024, 11:56 PM
Default Painting End of Control Arms to Look Like Bare Steel
Anyone have specific knowledge of how the "Big Name" Restoration shops paint/coat the ball joint
end of Control Arms to make them look like the bare steel some of them were on early 70's GM F Body Cars........
PPG in their VIBRANCE Line, has a LIQUID METAL Paint that sells for $600/pint.........which is not a choice Im opting for........
I do have a Aeresol "2K Aerospray Detail Gray" (Bare Steel Replication) from Eastwood.......
Anybody have experience with this product ???
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
The Following User Says Thank You to CamarosRus For This Useful Post:
DougsL78 (11-12-2024)
Attachments - The Supercar Registry upper control arm with riveted ball joint bottom.jpg Picture1119191700_1.jpg obdriveshaftstripes.jpg DSCN8346.JPG
Old 11-12-2024, 12:39 AM
X66 714's Avatar
X66 714 X66 714 is offline
Any of the items I needed to look like raw steel, I used a satin clear on after I made the steel look correct. This is my drive shaft...Joe
olredalert (11-12-2024)
Old 11-12-2024, 04:45 AM
...............And, HOW did you make the Steel Look Correct........?????
Chuck Sharin
[email protected]
Old 11-12-2024, 11:36 AM
X66 714's Avatar
It would depend on the part. That driveshaft was soaked in eveporust for 24 hours, rinsed, dried & then 0000 steel wool. Stripes painted & then clear coated everything. Some parts needed to go in the blast cabinet. I use black oxide & lower preasure so it doesn't scar the metal. Another thing is I live in southern Az so we don't have the rust problems other states may have. I can't afford what the pros may do so I have to experiment at home....Joe
The Following 2 Users Say Thank You to X66 714 For This Useful Post:
cheveslakr (11-12-2024), L78_Nova (11-12-2024)
Old 11-12-2024, 02:29 PM
napa68 napa68 is offline
https://www.amazon.com/RPM-Rust-Prev.../dp/B07MJCK3H6
69M22Z (11-12-2024)
Old 11-12-2024, 02:49 PM
I used to use the black diamond but switched to this several years ago. I run the air pressure at 40 psi at the gun to prevent metal marking. It will remove heavier rust/paint at up to 90 psi too, but takes longer. It works well on bare aluminum such as intakes too, but doesn't look as "original" as what I see others achieving. I see Northern doesn't have a store in your area...too bad, they are a good source of trailering and blasting supplies.
https://www.northerntool.com/product...um-grade-49360
X66 714 (11-12-2024)
Old 11-12-2024, 02:57 PM
I should add, for metal parts I will paint, I still use the diamond to achieve the equivalent 80 grit texture for the paint to grab. It's still the best for heavily rusted and pitted steel and will disguise much of the pitting to appear as blasted.
CamarosRus (11-12-2024), X66 714 (11-12-2024)
Old 11-12-2024, 03:07 PM
X66 714's Avatar
I forgot to add that sometimes I would need to go over the parts with a wire wheel on a drill after blasting to almost polish it before clear coating. Trying to remember all the details....Joe
Old 11-12-2024, 05:55 PM
I used the Eastwood "Bare Metal" spray bomb paint. My guess is that is what you are looking at in your photos.
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
Old 11-12-2024, 06:21 PM
WILMASBOYL78's Avatar
Post Bare Metal Paint...
I have had good luck with Rustoleum Stainless Steel enamel spray paint. Works pretty good for the bare metal look...
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
