Old 02-03-2003, 02:26 PM
Default Black Oxide
Has anyone used the Metal BLacking kit from Eastwood? And if you have how good is it?
Jake is my grandson!!
Old 02-03-2003, 02:39 PM
SS427's Avatar
SS427 SS427 is offline
Default Re: Black Oxide
Kim,
I use it quite frequently when I do not have a large amount to sub contract out. I have been very happy with the results with Eastwoods kit but it does take some experimenting with timing to get the right finish. I have had better luck with the finished appearance when the items are bead blasted before plating versus wire wheeling them.
Rick
Rick Nelson
Old 02-03-2003, 02:40 PM
Thanks very much Kim
Old 02-03-2003, 06:59 PM
Denis Denis is offline
The Eastwood metal blackening kit won't do a good job on previously plated (eg zinc) parts, even if you bead blast them first. A solution to this problem is to soak the part in diluted muriatic acid first to remove the old plating. Remember to neutralize the acid bath with baking soda (sodium bicarbonate) before disposing of it.
I've had very good results restoring my phosphated and blackened fasteners with a parkerizing solution from Palmetto Enterprises. A little goes a long way (i.e. a quart will last you a whole car's worth of phosphated parts) but you'll need a heat source and a stainless steel container to heat the solution.
(864) 246-3836
Greenville SC
Website
Old 02-03-2003, 07:07 PM
Didn't Eastwood offer a kit like this a few years back?? Kim
Old 02-03-2003, 07:33 PM
I bought Eastwood only the last couple of years, and can't vouch for what they carried before then.
The parkerizing stuff is pretty toxic and you need to bring the mixture to 205 degrees, so Eastwood may have dropped it for liability reasons.
Old 02-03-2003, 08:01 PM
Thanks guys for info
Old 02-03-2003, 09:35 PM
Caswell www.caswellplating.com has a black oxide cold coating kit for doing your bolts. I'm looking into this kit now. Phone 315-597-6378 in the US or 1-905-985-8627 in Ontario. They have a catalogue of their products available.
Old 02-03-2003, 10:12 PM
Keith thanks for the info
Old 02-05-2003, 01:48 AM
JRSully JRSully is offline
Kieth, let me know how you make out with that Caswell kit, read the site, looks interesting, for $25.00 might be worth a shot,
71 Porsche 911 Targa
