Old 11-10-2003, 03:02 AM
LeMans Blue X77 LeMans Blue X77 is offline
Default Muncie 4 speed ID info
Can anyone tell me how to identiify these trans?
PO422
PO204
This numbers came from the right side if trans is facing forward. stamped in.
Thanks [img]/ubbthreads/images/graemlins/worship.gif[/img]
Old 11-10-2003, 03:08 AM
Mr Yenko Mr Yenko is offline
Default Re: Muncie 4 speed ID info
P=Muncie
O=1970
4=April
22=Day
P=Muncie
O=1970
2=February
04=Day
You have seem to have missed the last letter in the code
A,B or C.
The "MOF"
"POTTER BROS. SUPERCARS"
72 Nova SS "My first car of 30yrs"
70 LS-6 Chevelle Double Blk 30k survivor
Old 11-10-2003, 03:10 AM
Case is extremely clean and there are no other letters or numbers but the input shaft has no rings cut in them.
Old 11-10-2003, 03:20 AM
Is the input shaft a fine spline or course spline shaft.
What is the size of the output shaft,Does it have a LARGE counter pin located in the front of the trans or a smaller pin.I compare the rear shaft size to a TH-350 Yoke or TH-400 Yoke.No grove and 1 grove is close ratio and 2 groves would be wide ratio."MOF"
Old 11-10-2003, 03:29 AM
crash crash is offline
These are either 1965 or 1966 model year Muncie's. 1967 and later used a letter code for the month. 1963 1/2 and 1964 had the P-code on the left side. If you could post the main case casting number I could give you the model year... Crash
Old 11-10-2003, 03:32 AM
one one of them it is 3952661 I'll have to get the other one from my buddies shop.
Old 11-10-2003, 01:09 PM
YENKO DEUCE REGISTRY's Avatar
661's aren't '66 or '67's! I think they started in '70 and went through '74 or '75?
Sounds like they might be replacement cases.
Marlin
Old 11-16-2003, 05:32 AM
jus4funn68 jus4funn68 is offline
If the case is a 661 and the input has no ring on the splines it would have to be an M-22. The spline number does not matter for that year since they made both fine and coarse spline input shafts on rockcrushers. Kevin
68SS Camaro L-78
Old 11-18-2003, 12:13 PM
Pantera Pantera is offline
I have worked on a lot of these 4 speeds and have never seen a coarse inpuit spline on a rockcrusher M-22. Are you sure of that statment?
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 11-18-2003, 12:25 PM
JoeC JoeC is offline
not all M22 were fine spline
don't go by rings on input shaft to ID a trans
To me, best way is look at input shaft gear.
If it has 26 teeth on 45 deg angle it's M21
If it has 26 teeth on a 20 deg angle it's M22
It it has less then 26 teeth it's M20
