Old 01-14-2004, 02:08 AM
Jim Mulvey Jim Mulvey is offline
Default Matching #'s question
I apologize in advance if some of you may think this is a dumb question. I recently purchased a mint 1969 Z/28, and I am very happy with my purchase. However, upon further examination I have reason to believe that the Muncie 22 is not original to the car. Its code is P1k28C, which if I decoded correctly is a 1971 tranny. FWIW, the seller disclosed all the #'s but I have been educating myself since I purchased the vehicle (mainly through here and other sites). So I don't feel cheated in any way. It seems that all other #'s match up and I am working on getting the car certified.
I quess I have two questions:
1) Am I right about the tranny code??
2) How much of a deduction is this when it comes to value, percentage terms would be helpful.
Thanks in advance!!
Old 01-14-2004, 02:23 AM
Default Re: Matching #'s question
I think the trans might be a rocker crusher because of the C. Does the trans. have a vehicle code? Maybe it was a factory replacement for your car under warranty. I think in 1970 the M22 went to fine a spline input shaft. (Not sure of date)What do you have? Sounds like a 1971 trans. case anyway. Depends on how perfect the car is. I don't think I would be over alarmed. Please fill out your bio! JMO Sam
Old 01-14-2004, 02:34 AM
Thanks for the quick reply. The only # I have is the P1k28C, which if I decoded correctly would be Muncie M22 rock crusher built July 28, 1971.
Old 01-14-2004, 02:36 AM
Sounds Good. How about a vin on it?
Old 01-14-2004, 02:38 AM
Excuse my ignorance VIN for the car or tranny??
Old 01-14-2004, 12:45 PM
drdave69 drdave69 is offline
The VIN derivative will be stamped near the code you mentioned. It will be something similar to '9NXXXXXX' where the Xs are the last 6 digits of the car's VIN. If there isn't a VIN stamped on the trans case, who knows where the trans came from? It does appear to be a 1971 assembled M22.
One of the best reference books on the market is Jerry MacNeish's '1969 Z/28 and SS396 Fact Book'. Pick it up and read it (over and over in my case). You'll learn quite a lot about your car thru it.
check your trans case again for another set of stamped numbers and let us know what you find.
Dave
Dave
1987 Grand National
Old 01-14-2004, 01:40 PM
Thanks Dr. Dave, I will get the # back to you when I get a chance. BTW, ordered the book last week.
Old 01-14-2004, 01:49 PM
Also talk to BKH (Brian Henderson) Super Car Workshop. Latrobe, Pa.
Old 01-15-2004, 01:15 AM
bkhpah bkhpah is offline
Is it a 660 case or a 661? 660 case is a 1969 case. I'll bet its a 661 from what little I see here..BKH
Old 01-15-2004, 09:56 PM
crash crash is offline
Yes you are reading it right, but is it 1970 or 71 callender year. I have a P0702 010 case with an early 1966 Vette VIN, so they were building 1966 model year transmissions in early July of 1965 calender year. So with the only info available of P1K28C, I would say July 28th 1970 to be used in a 1971 model year car.
Either why this trans is not correct for the car in question.
As a point of interest the earlist date use of a 661 case is P9R10A used in 29N119544 tag#9798974 Oct. 10th 1969.
The latest date use of a 660 case is P0T30C CT0 40753 Dec. 30th 1969 for 1970 model year(this is an over the counter transmission) These are dates I have in my collection, and talking to other builders/collectors havn't found anything much different, but always open to more info...Hope this helps...Crash
