Go Back   The Supercar Registry > Dealer Specific Discussion > Fred Gibb Chevrolet
Old 08-06-2005, 05:09 PM
Guest
Posts: n/a
Default Re: 71 Harrell F/C anyone know of its whereabouts
Continuing, when we received the car it had been primed dark grey by DH's crew. We sanded/stripped it down to the bare and painted it white. We also changed the trans, from a torque-conv. to a Crowerglide/TH400, built (reluctantly) by Fairbanks in CT. Back then Fairbanks was owned/run (?) by a nice guy named Joe something, and he had a German guy as his engineer. Joe told us the combo of nitro + blower would make more HP than what the TH400 could handle (how right he was!), but we knew we needed that low first gear to have any chance against elephant HP. After thinking about it Joe agreed to use us as a test-bed for his street-car trans's. He flat did NOT want us to put a Fairbanks decal on the car, and told us that he was only going to build it because we were complete unknowns and also didn't have much money. A Lenco was way beyond what we could afford back then, as was a hemi. We hoped that with the lower gear and my piston coating that we might be able to get the car to run halfway decent. But Joe was right, the trans. was unable to put up with what must have been about 1500 HP back then. It couldn't pull the revs down on the shifts, and after every few runs we'd pull it out, drain the stinking burned fluid out and drive up to see Joe. He'd open it up and shake his head, rebuild it and try new ideas, tell us not to bring it back, and send us away without charging a dime! We did this routine for 6 months.
But after 6 months we were just about broke so we sold the car. SO, where is it now? No idea, but we sold it to a guy who's father owned the/a flying school at Teterboro airport in NJ. He had a lot more $$$ and brains than we did, and took the blower off to just run on fuel. I guess he changed my pistons to get some squeeze back, and I was there when he made his first runs. The trans. would pull the revs down instantly on each shift--DUH! He later ran it on alky with the blower--same good trans. performance. That was the last I saw or heard about the car.
His crew chief was a sharp guy named Tom Wooden (sp-?) who later worked for Wild Wilfred Boutilier of Canada.
Old 08-06-2005, 05:33 PM
benesesso benesesso is offline
Hmmm, last photo didn't attach. Here's another attempt.
Benesesso
Old 08-06-2005, 05:43 PM
Here's the last photo. I scanned these from slides I took back in 1971. If anyone's interested I can probably find some more and scan them. My Nikon slide scanner is a real POS--the slides are REAL sharp.
The Following User Says Thank You to benesesso For This Useful Post:
PeteLeathersac (05-27-2022)
  #44
Old 08-06-2005, 09:11 PM
JChlupsa JChlupsa is offline
WOW, I can say all here would love to see more of the car and hear more of the history.
Aloha and welcome.
Old 08-07-2005, 02:03 AM
More photos of the car will have to wait-I have to get a new SCSI card for my computer-the slide scanner only works w/SCSI.
I had always thought the car had a Hardy chassis, but I see an earlier post here that said it had a Fletcher. I've never heard of Fletcher, so maybe someone can check out my photos and let me know.
Right after we *finally* got the car back together with different colors and a few other minor changes, and against my strong advice to just run it on alky for a while to get used to it, my partners decided to haul it out to NY National Speedway for our first runs. Because I didn't have the most money invested I was supposed to get my passes after the no.1 guy (another guy named Dick). He was a pretty cool guy, but none of us had any real experience with anything over ~500 HP. NY National didn't care about any fuel/NHRA licenses-just see if the crowd likes it.
Our first run found us paired with "Broadway" Freddy DeName, but our throttle wouldn't return all the way to idle so we couldn't stage the car. I did manage to get my eyes full of burned nitro fumes, and it doesn't feel good at all!
The next week at some NHRA strip in NJ we just did a burnout while being watched by some fuel-license holder (forget who) and blew the big Olds rear. The driveshaft slammed up and smacked the seat hard, giving my partner a sore rear for a while-I couldn't understand why he didn't climb out of the car for a while after we towed it away.<g>
After that we managed a few license-passes, but the iron heads were cracking around the big valves and forcing water out some of the sand-core/freeze plugs in the block. On the last run we made the water was getting bad, and dumping right in front of the right slick. The car ran arrow-straight w/o the water problem, but it was jumping sideways as the slick spun. Dick was on and off the throttle, with the car snapping around every time until the water was gone. It was something to watch, because it would snap right back where it belonged every time he lifted his foot. After about 4 of these cycles it was halfway down the strip, still in the low TH400 first gear, and Dick was so mad he forgot to shift. He went thru the lights at 110 MPH as it backfired thru the blower and sent the belt into the air. I later calculated the revs at something like 11,000 (4.11 gears), and all of the big Howards alum. rods were stretched a little. That was the end for us.
Here's a photo of the Beebe and Mulligan car before Mulligan was killed when the clutch exploded-the Nationals when Garlits shut off at the tree knowing what John was going thru.
Old 08-07-2005, 02:43 AM
Some great memories and a cool story.
By the way, welcome to the coolest site on the net...and keep the photos and the stories coming!
Also, I noticed that you're from Arizona. Are you located in the Phoenix metro area? I'm on my way to Pavillions and the cruise at 83rd Ave. and Union Hills in a few...then home for some cool
Old 08-07-2005, 06:29 AM
WELCOME!
Old 08-07-2005, 07:41 PM
Belair62 Belair62 is offline
Engine on that Beebe car is so cool looking....and is that a points type distributor or some weird mag ???
Old 08-07-2005, 10:34 PM
That's an early 392 hemi-based engine, with the points-triggered magneto at the back. The later 426's had the dist/mag drive up front.
I live out by Litchfield Park. Here's a photo of TV Tom's last (I think) front-engined TF car. Not even a mag. to slow down any exploding blower fragments! Talk about "in your face".
Old 08-07-2005, 10:40 PM
I can't make this software post more than one photo, so here's one of Clayton Harris-probably in NJ in the early 1970's. Clayton was VERY quick in those days.
