Old 07-22-2005, 06:25 AM
DSYenko DSYenko is offline
Default Fuel pump question
Is there any difference in factory GM fuel pump outputs or pressures.I have built a street performance 454 with 400-450 horse and used a 74 454 block and a 750 Holley and was wondering what fuel pump to use.I am trying to keep it stock looking but was'nt sure if a LS6 or Vette tri power pump had more output than the average GM pump? Also thought maybe they were to big to use without a return line since the heavy hitters in the later 60's had a return line .I am putting the engine in a 76 Malibu and it has NO return line.Any knowledge on this would be appreciated,Thanks Duane
EX 81 YENKO TURBO Z owner
Old 07-22-2005, 06:37 AM
Chevy454 Chevy454 is offline
Default Re: Fuel pump question
The Holley carb'd cars didn't have return lines...the Quadrajet cars got those. We run the standard big block AC pump on our Camaro, and we're putting out around 430+ HP at the rear wheels...last summer I swapped in a hi-flo Carter mechanical pump, and noticed no change...
Old 07-22-2005, 06:51 AM
NUF SAID on pumps,but why did the quadrajets only get the return line,and did they use the same pump as the Holleys that didnt get the extra line?
Old 07-22-2005, 07:38 AM
Any idea what that part number is for the AC pump you use?Id appreciate it,Thanks
Old 07-22-2005, 10:09 PM
k92 k92 is offline
My low mile all original ls6's fuel pump has the return line.I believe early ls6's did not have the return line.My car is a june car.
Old 07-22-2005, 10:17 PM
COPO COPO is offline
I saw a July LS-6 car that had a return line as well. I just assumed it was an LS-5 car. Is this change documented?
Old 07-22-2005, 10:50 PM
bad1racing bad1racing is offline
DSYenko,The part number could be 1 of 2.73-75 Chevelle 454 4" from bottom to mtg holes #6472381.73 Chevelle 454 4.5" from bottom to mtg holes #7470761.These are OE applications so anything is possible.Hope this helps.
Kendall
70 Nova SS ZZ427 TKO600 5speed 3.55Posi
Old 07-23-2005, 12:46 AM
DS: ours is the stock 396/427 AC replacement, available from our sponsor above (D&R Classic Automotive)...not near as fancy as what a lot of the guys are running, but it carries our fat @ssed Camaro through the traps at 113+...
Old 07-23-2005, 04:17 AM
Rob Thanks I will contact them and tell them i want what you have unless you have the number right off hand?
Thanks again
Old 07-23-2005, 05:51 AM
I believe this would be it, but when you call, make sure this is for the solid lifter big blocks (read: Holley cars):
http://www.drclassic.com/catalog/Cam...el/S00021.html
