Old 07-26-2006, 05:25 AM
Guest
Posts: n/a
Default Re: Value for a 1969 427
Paul,
The motor has 4 bolt mains, forge steel crank. The heads have a 840 casting #.Rods are 3/8 with a dimple on them.
Old 07-26-2006, 07:25 AM
Can you post the info on the block stamp pad and include a pic if possible. The stamp pad is located on the block under the alternator on 69 models.
Engine assy code = T0619XX June 19th assembly, XX - appl code
Paul
Old 07-27-2006, 01:34 AM
jfkheat jfkheat is offline
My guess on value would be $5000 or more if everything is in good condition. Has the block been bored? What intake? Are you sure it's a crate motor? It could possible be a COPO motor. If so, the value would be a lot more. You have probable already gotten quite a few PMs asking for info.
James
1968 Beaumont SD396
Old 07-27-2006, 03:40 AM
Guest
Posts: n/a
Block stamping CE 958752.The motor is standard bore, heads have had no work done to them.Intake # 163.Paul and jfkheat thank you for your time.
Old 07-27-2006, 05:21 AM
John's Avatar
John John is offline
...I think "CE" blocks were replacement or over the counter motors....send me a PM...if you decide to sell it
Old 07-27-2006, 06:00 AM
That is a perfect replacement engine for guys with 1968 and early 1969 427 cars that don't have the correct engines. I'm sure there are members here that would like to have it if you decide to sell. Your best bet might be Ebay. Whatever you do, don't let a machine shop deck the block and remove the numbers.
James
James
1968 Beaumont SD396
