Old 11-04-2006, 05:49 PM
Default Re: 69 L72 CAM
-----The 450hp engines were simply rated at a higher RPM than the 425HP motors. GM claimed that the insurance companys were screaming so just rated the engines at a lower RPM......Bill S
Old 11-04-2006, 06:05 PM
LS6 RAT LS6 RAT is offline
Bill,
In Karl Ludvigsen's Corvette book both the '65 L78 & the '66 L72 were rated at 6400rpms.
However the later engines such as the '67, '68 & '69 L71 which also was a 11:0 to 1 compression rated engine, did indeed rate their 435hp at 5800 rpms. I don't know what rpm's the '70 LS6 used for their factoring with a 11:25 to 1 compression, but the '71 454/425hp rating was also rated at a low 5600 rpms, and this with a factory compression rating of 9:0 to 1.
2 1971 LS-6 Corvette coupes (Duntov's last stand)
Old 11-04-2006, 06:49 PM
Warren,
----Good to hear from you!!!
----Nolands book (PG.354) says that 450hp engines were rated at 6400rpm while 425hp engines were rated at 5600rpm. Both the 450hp and the 425hp were L72s. I believe Ludvigson was referring to the much more common 427/425 rating that was prevalent most of the production year of 1966........Bill S
Old 11-04-2006, 07:53 PM
From my experience, these engines are not making more horsepower at the higher rpm above 6K. About all you are going to do shifting up there is drop a valve, if you are running stock valve springs. A friend's L78 with more cam shaft and head work, ETs best shifting at 6K. Our L78 and L72 are both 4 speed with 4.10 gears. The 427 is a ton stronger in all rpm ranges. The bottom end torque and the extra hp on the top end make a bigger difference than the 31 cubic inches would indicate. Perhaps the bigger bore unshrouds the valves allowing for better breathing. The minor differences in cam shafts would make an insignificant difference. I wouldn't put much credence in factory ratings. The numbers look good on the breather though.
Old 11-05-2006, 03:19 AM
Keith,
I had a '69 L78 engine in a SS Camaro Convertible, and had this car restored completely. I was disappointed in this engines performance, it did not feel very strong, and many people had extolled stories on how powerful these 396 engines were. This car ran a M20 transmission and a 3:55 ratio axle. My LS6's with their low compression seemed to pull harder and run stronger. Heck, my friend Larry Weymouth, last year at the Pure Stock Drags ran a 13:12 with his stock '71 LS6, and this was with a 3:36 axle ratio.
Old 11-05-2006, 04:12 AM
Warren,
There was a recent thread here about our beloved SHP engines,
the vast manufacturing tolerances employed back in the day,
and how these tolerances effected the compression ratio,
and ultimately the power output of that particular engine.
Indeed, one member here posted that an L/72 ( 11:1 compression )
actually spec'd in under 10:1 compression. Another member
wrote about deck heights being different by as much as 0.020
So, you can possibly see why your particular BB ran less than steller.
Needless to say, I will never build another engine without blueprinting it first.
Old 11-05-2006, 07:53 PM
The two L78 cars that we have/had would probably run mid to low 13s. They both had headers and appropriate tuning. Nothing spectacular considering all the good equipment involved. The gas mileage was no better that our 427 which did perform pretty well. The actual compression ratio tended to be about a point lower than that listed. I was told by a fellow with several COPO cars, that these engines were honed to the outer limit. This is what accounted for their free revving at higher rpms. Ours certainly didn't fall off over 6K like the L78s did.
Old 11-07-2006, 06:59 AM
Here is some proof about what I said in my post above. I called on an ad in Decembers Hemmings Motor News issue, under the Camaro/Chevelle parts section ads. A long time muscle car enthusiast/collector for 30yrs was selling a lot of parts. In his ad he listed an NOS LS6 cam & lifters, I called and he stated that he pulled this camshaft out of a LS6 crate engine bought in the early '80's. I had him read me the stamping on the end of the cam, it was stamped 3144, which is the 3863144 stamping for the part # 3863143. This camshaft has a grooved rear journal. So here is proof that this camshaft was indeed used as the service replacement cam for the original non grooved camshaft part # 3904362 and stamped 3904366.
