Old 05-08-2007, 11:12 PM
quick-bowtie quick-bowtie is offline
Default 1970 Camaro SS396 REAL DEAL needs finishing..
I bought this car last year with intentions of cleaning and preserving it, When I bought it it had original paint and I tried to save it but ended up painting the car. I just got it back from the paint shop and it still needs to be wet sanded and buffed.
Car has BORN WITH NUMBERS MATCHING Engine, 12 bolt rear, and I believe transmission (I will have to double check) car is was so correct and original so Ive got to believe the trans is also original but I will check.
Original Citrus Green car with Dark green interior, Interior is original with only the front drivers bucket and dash needing replacment.
Engine runs good it is currently out of the car because I was going to detail everything, I put so new gaskets etc just basic freshing. Very solid car, rear of truck pan by the tail light could use alittle minor minor work but definately doesnt need replacing.
The first few pics are when I bought the car and the rest are as it is in the current state.
Car has factory 12 bolt with sway bar, gauge package with tach, tilt wheel, console, Citrus Green, Good solid legit easy project. I can drop the motor back in if needed.
PRICE 17k FIRM. I have more than that into it. 507-208-0191
69 NASCAR PACECAR Camaro 1 of 7
68 Shelby GT500 Convert
Some other GM and Mopar
Old 05-09-2007, 01:18 AM
AutoInsane AutoInsane is offline
Default Re: 1970 Camaro SS396 REAL DEAL needs finishing..
What hp is the engine? 375???
Bill O'Brien
1974 Jeep CJ5 - 304 V8, Edelbrock Intake, Holley 650, MSD Ignition, Patriot Headers
Old 05-09-2007, 02:42 AM
Looks like a 350 Hp L34. Is the rear gear a 3.31 posi?
Very nice car for the money, should be a looker when finished.
Paul
Old 05-09-2007, 06:06 AM
Its a 396/350hp car. The car is very solid and all there.
Old 05-09-2007, 06:08 AM
I'll check the rear end number tommorow.. Ive never looked for a built sheet where are all the locations there in on a 70? Maybe I get lucky and find one.
Old 05-09-2007, 07:12 AM
Looks like a Van Nuys built Camaro with BL on the trim tag. The LA plant frequently put build sheets on top of the gas tank before installation. With a little luck it may still be there. Also, check under the carpet, behind the rear seat, in the front seats, etc. My 70 Z-28 is a LA built Camaro that once spent time in Minnesota (I found a parking receipt for University of Minnesota dated late 1970 under the seat)and ended up in Georgia. Good thing since the car has virtually no rust.
Also, check the axle tube stamping for the three letter code and build date. I found the VIN stamped on the Turbo 400 right above the pan rail on the drivers side. The LA plant sometimes used letters of different font sizes. Can you post a pic of the Engine, Trans, and Rear Axle stamp? Thanks,
Paul
Old 05-09-2007, 03:27 PM
Gregs396 Gregs396 is offline
Looks like a very decent solid project car. I wish that I were a bit closer, so the shipping wouldn't be such a huge factor. If I could swing by with my trailer, I would be there to check it out.
Greg
Old 05-11-2007, 01:25 AM
akcamaro akcamaro is offline
I've got two LA built 70 L34s, and I found the build sheets for each of them under the carpet pad in front of and under the drivers seat.
70 rs/ss 396 L34 Camaro
78 W72 4speed Trans Am
Old 05-11-2007, 07:19 AM
Finally made it out to my buddies shop (he is putting new seal etc in the motor) Checked trans tonight it also it 100% original and correct it still has the tag and the vin is clearly legible on the lower driver side (thanks Greg). The car is so unmolested Im really starting to have second thoughts about selling it will be a cool car when its complete.
Old 05-11-2007, 08:47 PM
Not to steal the thread but does anybody have a Nos or used rad shrould like the picture above. Thanks Kim
Jake is my grandson!!
