can anyone tell me if this is a 69 chevelle or 69 elky regulator? thanks
ANYONE????
hey king,
is it possible that the two wdw regulators interchange? making them useable on either model alan ![]() |
Alan, i thought they did originally but i was told twice after that they were different. Id guess 68 thru 72 chevelle are the same and 68 thru 72 elky are the same, but i dont think they interchange between the different models.i could be wrong though.
The Elky ones are different than the Chevelles.....
Steve |
If I recall correctly, at least on the manual regulators, the appearance is identical but the spring tension is different. Since the 69 window is larger it weighs more and thus requires more spring tension to raise it. The same concept probably applies for power windows, but instead of a stronger spring you have a stronger motor in a 69 unit.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black 1970 LS3 Malibu 400 BB convertible 1970 LS3 Malibu 400 BB coupe 1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange 1970 Chevelle Concours Estate LS3 400 BB wagon 1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black |
What about the regulators??
I've got a set of pw regulators that are supposed to be off a 69 Chevelle and the door regulators are different than the one in your post. The regulator that I have has an extra arm between the gear and the main arm. The main arm on the ones I have measure 22" from tip of the roller to the opposite end.
Phil Woj. |
Thanks woj, thats exactly what i needed to know. The regulator i posted was with a 69 elky,and should be different than a chevelle but i wasnt sure.
Thread Tools | |
Display Modes | |
