This is a real and rare original stamped L89 shortblock that has never been apart and still has all of the pieces still intact. The block is standard bore and turns over very nicely and has clean cylinder walls with no lip on them. The block casting number is 3955272 and is dated H-19-8 but did not go through the line until T0219KG which is February 19th of 1969. The vin number for the chevelle is also still intact on the front pad. This is real and I will stand behind this shortblock as the real thing and not a restamp. I'm asking $8500 for this one of only 311 approximately made aluminum headed chevelles in 1969 model year. I can ship this item if you cannot pick it up. You can reach me at 330-770-2517 Dennis Vugrinovich.
Dennis Vugrinovich |
i was umder the impression they made 311 L89 CAMAROS...did they also make the same amount of Chevelles?? I thought the number was a lot less???
You could be correct. I was told it was around that number so I put in the add approximately but if you have the correct amount I would love to know the answer to it.
I think?? the Chevelle number is a little over 400...including 4spd and auto.
For the 1969 Chevelle,Tonawanda produced:
333 KG M/T coded 396cid blocks. 12 CKG M/T coded 402cid blocks. 66 KH A/T coded 396cid blocks. 1 CKH A/T coded 402cid block. ---------- 412 TOTAL L-89 Engines produced. 400 TOTAL L-89 Chevelles assembled. ---------- The 12 remaining were OTC Service Engines. |
Thankyou
mine is TO114KG
Is your block casted early like this one is too by any chance or is it a little tighter?
i'll check...
where is the casting date on the block again? can i see it easily? chris |
you know,
it would be really neat to try and find that l89 chevelle that came with your engine. have you tried searching with your vin number? |
